- 8 Jan 2007
- London & Dubai
I would get the the TFV8. The Baby Beast is useless.
Got a bit of a problem. I bought some coils for my Smok Alien with a Baby Beast tank. They are the V8 Baby Q 0.4 Ohms. I've set the Ohms to 0.4 but it doesn't pull well when I take a drag from it. Only a little bit comes out and it feels difficult to take a drag from it. I have no idea what the problem is with these? These should be the same coils as came with the set and I got them from Fast Tech. Can anyone offer any help at all? I really need to get this working soon. Vaping has been nothing but trouble for me. I've obviously not very good at this.
Thanks for any help.
when you say you set the ohms, are you running standard kanthal coils in temp control mode?
is there anything in the way of bubbling, or incorrect setting of air flow?
it's quite possible this is smok's terrible coil qc rearing its ugly head, they have a tendancy to pack far too much cotton in.
To be sure, make sure the mod is in wattage mode, fire it; remove the tank with the mod still switched on, fire it; at this point it should say "no coil". Then re-attach the tank, fire it and let it re-asses the coil ohms. I've had issues before where if you switch the coil while the mod is off it doesn't pick up the new ohms values properly.
Something else to try is to fire it for a second without vaping it and watch the screen for errors. They're easy to miss if you've got the screen under your chin![]()
Thank you both for your replies.
Turns out the problem is I'm a retard. The air hole was closed and I just had to open it up. Sorry for being stupid. I'm very new to all of this and don't think things through properly.
Let me know how the ammit is, its between that and the kylin for this months purchase.
I'm not so much particularly fussed about the tpd regs as such, I'm just thinking of downgrading to a smaller tank running a bit less power and using less juice, so thought why go down to a cleito when eventually coils will become difficult to get when I could get a tpd approved tank that I'll always get coils and things for.If you're buying from ft then don't worry about tpd limitations and give your self a broader selection![]()
Vaporized currently selling the TFV8 at £16.99 so grab one while you still can. I got one last week.I think that's what he meant actually, my mistake!
Which coils would you suggest to go with it? Before the restrictions, I will probably buy it, try the coils in the pack and then go from there.
Are we allowed to post deals that are happening online?
