Can u recommend a 3.5inch backing plate as I looked but was abit lost on which to choose.
I got this one with my kit www.cleanyourcar.co.uk/polishing/polishing-accessories/3-5-dual-action-spot-pad-backing-plate/prod_66.html
I was going to buy some but just got given some dodojuice wax and meguiars quick detailer and clay lolTried hydr02 for the first time today, it's actually impressive how easy it is to protect your car with it! We'll see how long it lasts I guess but first impressions are great.
looks goodThanks for the advice i just ordered this lot.
Where was the above order placed?
So I was washing my car yesterday and my trusty Nilfisk pressure washer stopped working. Had it a good few years, I guess they don't last forever. Slightly annoying in that at christmas i purchased a 15m hose for it and I have a snow foam gun for that fitting too. SO I guess that locks me into a nilfisk machine for my next one. What would you guys recommend to get for a new machine?
What do you guys use?
i use a karcher k4 for the last few years with no problems .But the All Black 8 from directhoses is getting a lot of good reviews and is worth a lookSo I was washing my car yesterday and my trusty Nilfisk pressure washer stopped working. Had it a good few years, I guess they don't last forever. Slightly annoying in that at christmas i purchased a 15m hose for it and I have a snow foam gun for that fitting too. SO I guess that locks me into a nilfisk machine for my next one. What would you guys recommend to get for a new machine?
Never clay barred before but looked into it, the time consumption has always put me off. What Sealant is effective and easy to apply for after use of a clay bar?
Second wash seems unnecessary to me.
If your car is not too bad I found the clay glove products pretty decent for how much time they save.
The clay mitt suspends the contamination from what I recall, making a second wash necessary. For the time it takes however, definitely worth it.
