Acme I wish someone would just get a grip of you put your head in a vice pop your eye out and tell you "no" this is not the way to buy cars.![]()
I will try and take pictures but it's more of a get it out and in in a day sort of thing so I probably won't have time. I could stick a drift Cam to the side of my head I guess...
That's the plan
Results:
Idle seems to be hovering around 700-740 now. Still lumpy, possible misfire. - Might get some new plugs for it when I do a service in summer.
Less "wooosh" noise from the engine bay when accelerating.
No DTC Code from ECU after a 10 miles drive about. <- Most important thing.
Vacuum was 17 before and now its 20.4 on idle.
I will see if the error is now gone tomorrow after my 25mile trip to work. Hopefully, it was simply due to the intake clamp missing.
I have a feeling the previous owner removed an expensive intake prior to selling.
He then must have just stuck it all back together without giving a crap.
I also made a note of the "2015 turbo" that was supposedly fitted to this car... in actual fact, I very much doubt that it has ever had a new one in its life. The metal discolouration is the exact same as the rest of the engine metalwork. If it indeed did have a turbo less than 2 years ago then it would not.
Sounds like a bad MAF or MAF calibration. If they had a bigger intake on previously which increased the MAF housing diameter the map would have been tuned for it. Could be the reason it's lumpy. Mine needed to be revved when started from cold when I had a 3" MAF cal instead of 3.5".
Post up the reg and I'll see if my tuner tuned that car also and he'll be able to provide a lot more info. He's tuned most of them in the UK via accessport/versatuner.
I think they must have been bored...
That's harsh - I got pulled in Shoreham by a very friendly WPC for having a sticker for a front plate that was probably 60% the size it should have been and just got a warning.
A few weeks later i got pulled by a very grumpy biker PC who still then only gave me a producer.
Still had lots of fun trying to convince the local garage that the import-sized plate (Shown in sig) I replaced it with was legal - even though I'd printed the legislation.
When reading this I honestly do not know whether a "good" Acme purchase is a terrible thing or a brilliant thingBest Acme buy ever, legendary.
What size are those legal import plates? They are what I'll be getting. Since it is an import anyway.
Wut.....My fronts are 195 on an 8J and they look fine!
Rears are 195 on a 9J and they do look pretty stupid...
