Is there a list of differences between the two beta bios currently available?
Currently on 1107 running 3600 Team Group memory stable at 2933.
Try GSAT in BASH terminal. That'll find errors faster than anything
Perfectly normal, just XFR doing its thing. Voltage can spike up to 1.45v and even higher momentarily, nothing to worry about.Hi guys,
Hopefully this is the right place to post.
Owner of a 1700x here. Really pleased with it, but am wondering why the vcore (in Ryzen master) spikes on idle-anywhere up to 1.45ish. Interestingly in games and benchmarks it seems to stay locked at around 1.25 I think.
Its completely stock, not overclocked. Same behaviour happens with high performance power plan and the newer ryzen balanced power plan. I thought switching to the ryzen balanced power plan may affect this but it did not.
Any ideas? @AMDMatt may know!
Thanks,
B
You can most likely undervolt the CPU to around 1.35v or even lower if you run at stock frequency.
Well made the mistake today of updating my MSI B350 Tomahawk to BIOS Version 7A34v15. So no boot, no post and this lovely greeting on the screen
OOPS!
Luckily l have a Gigabyte Brix to tide me over lol.
How did you update the bios? Was it a beta?
Nope, official update. Using M-FLASH via BIOS.
Tried the MSI recovery procedure, however does not appear to work, computer just runs with the above posted message with fans spinning etc.
Ouch! Should not do that with official non beta bios. Especially since you flashed it from within the bios and not windows.
Time to return the board?
Hows memory tests going ??
dunno if You looked in to this but
Originally Posted by elmor
Depends on your specific sticks/ICs, CPU, DIMMs per channel, single/dual rank. A few numbers that worked well for me:
Samsung B (SR) 2x8 = 53.3 ohms
Samsung B (DR) 2x16 = 80 ohms
Samsung B (DR) 4x16 = 43.6 ohms
Hynix A (DR) 2x8 = 53.3 ohms
Hynix A (DR) 4x8 = 40 ohms
Atm no one knows what auto is on new bioses.
Crosshair 6 hero. However if using samsung b die memory that should run at rate on most boards once they roll the new update out. ( Only the crosshair has it at the moment)What's the best board to get involved with a 1700? Hoping to do 3200 RAM...
Makes me more worried to update from v14.Nope, official update. Using M-FLASH via BIOS.
Were you overclocked at all? If so did you reset everything to default before the flash?
