That would make sense, if they are only putting it on two boards and one is noticeably cut down then it would probably be uneconomical to use a different chip for each board.Believe its the same chip
Silly good, or silly bad??Gaming 5 now at silly price.
strange - I don't see anywhere listing it as 'silly' good.Silly good
on OcUK - they are way out of sync with their competitors on pricing of both these boardsIts £179 - https://www.overclockers.co.uk/giga...ocket-am4-ddr4-atx-motherboard-mb-554-gi.html
Only £10 more than K5, thats silly good.
So now the 370 Gaming 5 in this weeks deal (£179.99) ,on OcUK - they are way out of sync with their competitors on pricing of both these boards
ab350 Gaming 3 is £101.99 & also in the deal .
K5 not in this weeks deal but got the turbo bc chip ,
Then again the Gaming K7 is in this weeks deal at £217.99 ....
Will Wango , Tango with that price of one of them ..Mhmm
Very good video below , K7 & 5 may be the most efficient out of all the current AM4 boards
PCB Breakdown: Gigabyte X370 Gaming K7(same VRM as Gaming 5)
sooooo,
the k5 can be had for £149.99
the 5 can be had for £175.99
the k7 can be had for £200.99
someone make my decision for me!!
cpu will be watercooled , will never dual card the system but will likely oc (though can't imagine i'll be pushing for a world record oc.
so which board is the board for me!!! heeeeelllllppppppp
I have being so indecisive!
not really - I need someone to tell me which board to get!hope this helps
I jest, cheers for the info
@Darren_uk, mind if I ask why you're changing from the gaming 5 to the gaming 3?
any higher you need a good liquid coolerAlmost certainly going 1600.If your going 1700 chip splash out on the K7, saving money with 1500/1600 go K5
Out of curiosity do you say 1700/K7 due to the 1700 needing the better board vrms for oc'ing?
I'll likely plop a zen+ chip in at a later date so thinking I should maybe go with a better board now.
