What RAM are you getting/bought for Ryzen
18 Oct 2002
North Wales
3600 was a no go, although to be fair I didn't increase the voltage above 1.38. It booted to windows but rebooted shortly afterwards. 3466 is stable in P95 at 15-15-15-36, well stable for an hour before I stopped it.
Ste
Ste
18 Oct 2002
New Gigabyte 1006 bios on the gaming 5 has my G Skills 3466C16 booting straight up at 3466 off the xmp profile. I couldn't even post at 3200 before.
Which RAM is this please? That's my preferred board choice. The RGB or the ripjaw?
Cheers
4 Sep 2005
London
Please let us know how you get on...
Well in my eagerness to swap, I forgot to do benchmarks on the TeamGroup (hynix) ram.
But I've managed to get my Ripjaw V 3600 booting into windows at 3466 18-18-18-38.
I'm sure with some tweaking I can get it to 3600.
Here's some AIDA64 speed tests.
3200-16-15-15-36
3333-18-18-18-38
3466-18-18-18-38
18 Oct 2002
North Wales
3200-16-15-15-36
3333-18-18-18-38
3466-18-18-18-38
Are you able to tighten those timings at all? I'm seeing significantly higher L1/L2 scores at 3466 / 15-15-15-36 - about 200GB/s higher.
18 Oct 2002
North Wales
I'm running at 3200 14-14-14-36, haven't benchmarked yet though. Might be able to improve on that further
What motherboard is it? I just tried 18-18-18-38 and am still quite a bit higher than you - although I'm on an R7 1700 that might explain it?
18-18-18-38
15-15-15-36 (Although CL is showing as 16, must be a BIOS bug)
4 Sep 2005
London
18-18-18-38
Possibly, I'm using a Taichi with the R5 1600. What ram are you using? Do you change any other settings to get it stable at 3466?
18 Oct 2002
North Wales
I'm using the Team Group Dark Pro (3200), all I've done is voltage to 1.37v and timings as per above. Can't get 3600 stable at any voltage or timing, so I think this is the limit. Did try 14-14-14-35 but froze booting into windows.
Ste
Ste
18 Oct 2002
I have just bought a Gigabyte X370 Gaming 5 and a 1700... looks like the G Skill RGB is pretty decent compatibility wise? And it looks cool :)
Do people think that the 3200 kit is sufficient or is the 3466 / 3600 worth the gamble on the hope that future BIOS will like it?
It will be 2x 8gb so hopefully ok...
5 Nov 2010
Hertfordshire
The main thing about the RAM is you really want Samsung B-Die ICs to ensure a generally hassle free time. These can be found in 3200MHz CL14 kits and i believe 3600MHz CL16 kits or the high frequency kits. I believe the 4000MHz CL18 are Samsung B-Die too.
Hynix MFR ICs aren't too bad, my Corsair Vengeance LED 3200 can do 3200MHz CL14 with 2x8GB and a little work but 4x8GB is a struggle for 2933MHz. I can (and will faff) some more and i'm sure i'll get 3000MHz stable, but doubt i'll be able to get the same speed and timings as 2x8GB.
Edit:
Here's a useful list:
https://www.reddit.com/r/Amd/comments/62vp2g/clearing_up_any_samsung_bdie_confusion_eg_on/
Ste
Ste
18 Oct 2002
That's really helpful, thanks. I didn't notice until checking but the 3600 kit I had been looking at (£205) was CL17 vs. the £235 for CL16 kit (both B-die) or £165 for the CL16 3200.
I think going for 3600 is probably worth it for +£40 but not for +£70 (vs. 3200)
Any reason to worry about the CL17 position being too loose, or good to go?
Cheers!
Ste
Ste
18 Oct 2002
I'm looking at this -
Manf.Code: F4-3600C17D-16GTZR
On the list there is no "R" on the end - does that make any difference?
G.Skill Trident Z 3600 MHz CL17 - F4-3600C17D-16GTZ 8Gb - Samsung B-Die Single Single Jedec Info
Ste
Ste
18 Oct 2002
Cool, thanks. Turns out the 3200 stuff sold at other stores (OCUK don't seem to stock) is all E-die so glad you helped me out there - cheers! 3600 ordered :)
