You got me, 10 internet points for you.*Reigns![]()
It's early and I was on the **** last night.
Your hearing needs aids (not the disease)....
You just get wheelspin. MDM on and first gear mash seems perfectTraffic Light GP loyalists would disagree!
I was going to offer you £22k cash, but i dont think i will now. That sounds reckless.I need to try it in the 530 before I sell it.
Instead of what, false hope and promises?£22k cash
That's my thinking as well, I have to modulate the throttle if I put the gearbox in sports and floor it.I don't think you will get it much quicker than just flooring in Sports mode as I have always found them light on traction from a standing start, a 535d is almost comical if it is wet.
Interesting. Don't need to hold the brake in the M5 and you can set the launch revs with the cruise control (to a max of 2900rpm I think).
Put the car in Sports+, gearbox in sports and foot down very hard on the brake pedal (first time I didn't have it on hard enough) floor the throttle a flag flashes up on the dash and let go of the brakes. I don't think you will get it much quicker than just flooring in Sports mode as I have always found them light on traction from a standing start, a 535d is almost comical if it is wet.
My 2013 BMW F11 (5 Series Estate) needs new front brake pads, according to the i-drive.
Are all brake pads compatible (in terms of tracking the wear) or do you need specific ones compatible with the wear sensor?
What tyres do you have? I have Turanza run flats on mine (factory tyre?) and it breaks traction if I floor it in sports from standing.Complete rubbish unless you have dreadful tyres.
I have an F10 535d and a E89 35i DCT and in Sport+, maximum attack driving I rarely if ever break traction at the back, even from a standing start when trying to pull away as fast as possible.
Oh they're awful! So noisy, break traction easily, too stiff. I'd be getting some MPS4 if I weren't selling shortly. Are they not factory fit?Well there you are then! F1A3 / CSC6. I'm not surprised you're having issues with your mid-range tyres![]()
Just thought I'd chime in to say that the Goodyear Excellence RFTs on the back of my 535d are terrible when it is cold. We had a day here when the temp in the morning was 3c and even after about 10 miles they were still really bad. Today in the damp was warmer but they still really struggle with even moderate throttle application. Such a shame that they are basically brand new as I wouldn't otherwise hesitate to bin them.
