This seems stable at the moment, albeit at 1.45v
which RAM?is it still as 'vital' to get Samsung b-die ram now that the 1.0.0.6 Agesa bios' are starting to circulate. stuck on what ram to get to go with a gigbyte gaming 5 board and r5 1600. hoping I can just go with any 2x8gb 3200 now?
Ah **** it. Spent god knows how long himmimg and haaaing over a motherboard. Now to do the same for ram.Not vital, but still by far the best choice.
Any chance you can link the part number? Though, the more I like rbg stuff (who doesn't like pretty lights!) it'll be wasted on my system, as it'll be underwater - UV lighting with reactive coolant so don't want too much 'bling' to detract from the main features.Me too. Bite the bullet and go all in.
Got some g skill RGB 3600 B-die in the end.![]()
F4-3600C17D-16GTZR
According to the link I posted earlier it's B die.
Believe the 3200 is now a lottery between Samsung E and Hynix so do your research...
but then that defeats the purpose of rgb - don't go subtle if you're rbging!! lolCan set RGB to a dim white which looks quite subtle![]()
Nicewhich RAM?
Try running the TPU Memory Test for 15-30mins.
cheers. but think I'm just going to go with CMK16GX4M2B3200C16, it's about 40 quid cheaper than the F4-3600C17D-16GTZ. seems it's hit and miss if they are Samsung b-die (depends on the version you get) but can't be arsed faffing round looking at ram any longer and not over keen on dropping close to the price of the r5 1600 chip on ram just for a few more fps/bench pointsF4-3600C17D-16GTZ is the same RAM without RGB, if you wanted.
I need help deciding between these GSKILL TridentZ models for my R5 1600:
DDR4-3200MHz (PC4-25600), 16GB (8GBx2), CL14-14-14-34, 1.35 Volt, Unbuffered, Dual Channel Kit
