overclockers dream
Was true. Overclockers still dream about overclocking the Fury X.
overclockers dream
Vega die shot: https://videocardz.com/newz/amd-releases-vega-gpu-die-shot
Interesting quote from the article:
The memory is codenamed GPA022GA2656, which does not correspond to SK Hynix nomenclature. Are those memory chips made by Samsung?
iMac Pro... What the heck?
Pretty all space grey including keyboard with black keys and space grey moose.
Also spotted on the iMac Pro tech specs is a 56 CU Vega card, and top one is 64 CUs.
https://www.apple.com/ie/imac-pro/specs/
Worth noting that 56CU model will be clocked at 1535 MHz, assuming the 11 TFLOP single precision figure is talking about the base model.
Also running slower HBM2, most likely Samsung according to Videocardz as the model numbers don't match SK Hynix.
The Vega cards in the iMac run at 400GB/s, possibly the base model as well.
Where as the Frontier Edition has 480GB/s
Also true indeed. If it's running at slightly slower clockspeeds (the core that is, for thermal constraints) hopefully that won't matter. We've all yet to see how well HBCC works in practice across many examples.
970 '4gb gddr5 memory'overclockers dream
Oh and the rops too dont forget them.
Nvidia do it too. Maybe if they said upto 4gb gddr5 memory they could have passed lol. However everyone knows that overclockers statement was a slip up. The 970 was not.
I'm looking forward to the Frontier Edition's launch so we can see what's what.
Here's a Vega die shot in the meantime.
And I've seen some people estimate the die size around 490mm^2 from it. Since the HBM2 stacks are meant to be 92mm^2 each.
You replied to some one in regards to what amd have stated. When amd said most improvments made since gcn was introduced. You replied with acording to amd. Then you replied to, well they know more than us with overclockers dream. Thought that was abit childish tbh. So i stated what nvidia have said before to enlighten you to the fact that its not just AMD that say stuff too. Nvidia have done it before and overclockers dream was more of a slip up than owt but AMD are ridiculed for it ever since.What does this mindless rant have to do with AMD?
Not realy defensive just pointing out you cant just knock AMDs credibility like that for overclcokers dream when it was just a slip up. See nvidia state the specs for the 970? They got away with that tbh. It was a non problem. I dont see D.P discredititng what nvidia say based on that. If it works one way it works both. Which is my point.Defensive much? Sheesh.
