Caporegime
- 20 Oct 2002
- Wish i was in a Ramen Shop Counter
GPU alone would cost more than the console.![]()
Bargain then, considering its part watercooled as well.
An RX580 manages 15fps in Ghost Recon Wildlands at 4k. I bet Xbox one x does a bit better...
No idea why it needs to be compared to pcs all the time. It's a games console...
you can get an RX580 for £250. Which is actually 6.2tflops.
Ok, £250 left for CPU, RAM, mobo, bluray drive, HDD and PSU.
Go!![]()
Did they make mention of the upscaling for Xbox 1 games? I seem to recall reading the PS4 Pro doesn't let you upscale graphics/performance on all games, if you have a 1080p screen.
I am wondering if they mentioned anything about using the X on a 1080p screen? I like the idea of playing Xbox 1 games (mainly exclusives) on it, with graphical improvements until I have a 4k screen, to maximise it's potential.
Then add the rest not forgetting software and a 4k blue ray player with software. The RX580 also struggles at 4k.....
Can't all the "Can't all the may as well build a Pc" people make a post in the PC thread and let us console people enjoy and talk about our new uber console.....
. I only said it could be done for a similar price.Also, regarding the "performance benchmarks", as said, all these review sites just max everything, even AA when there is no need (especially for 4k) so if you set the games up correctly i.e. reduce the settings that bring no benefit to IQ, only performance killers then a lot of even "mid range" GPUs are capable of very good performance at 4k, this is where the PC is superior for gaming in some ways as you can choose exactly what you want.
The biggest problem with PC is release day where optimization isn't done well and it takes months to get a game working as it should have.
I'll just lay it all out on the desk![]()
?This is why we buy consoles. I don't want to spend ages setting up a game before I play I just want to get on with it....![]()
Can it do 60fps at 4k? Not really a comparable card imo.
Yes it can with the same settings the Scorpio uses.
How is it not comparable when it's practically an identicle gpu?
Do you know what settings Xbox One X is using ?
