I used "TV calibration with Darko" channel - his recent Calibration video for MU6400 sorted me nicely.
Samsung TVs
From the settings page, under picture settings, select expert settings. Scroll down to "HDMI UHD color". From here you can select which inputs have this feature enabled. You will have to select PC mode for the input as well.
Thanks, I will give this a go. But I think the real problem is that I cannot get the chroma4:4:4 mode to work correctly above 30Hz and it is driving me mad.
The issue is the Sammy MU6400 fails the chroma sub sampling test spectacularly at 60Hz - it’s almost unsalable as I get a headache after an hour or so.
I have a GTX 1080Ti so I have been trying to set the Output colour format in the Nvidia control panel to chroma YCbCR444 @ 60Hz without success
I have tried (all connected to HDMI port 1 on the TV):
- 2 different “high speed” HDMI cables where the best stable output format YCBCr420 @ 60Hz
- Same HDMI cables and active display port adapter which will give the option to select YCbCR444 but only at 30Hz
- Display port cable again only allows YCBCr420 @ 60Hz
For the Sammy MU6400 to be usable the I need YCbCR444. I assume there is something wrong with my cables.
So my question how do people get the Sammy to pass the chroma sub sampling test at 60Hz? What settings do you have and which connectors are you using?
Go for it! I don't think I can go back to sitting at a deskI'm thinking of going for a 65 inch panasonic 902B and being a couch gamer.
The Hisense M3300 is fantastic, and considering it's £300 it's a bargain. I love mine so much, that I bought a second one for the bedroom.
The clarity is perfect, as are the colours and blacks. No bleed or cloudyness either.
It puts the display on my dell xps laptop to shame that's for sure
Where are you finding these?
The catalogue shop doesn't have any
The Poorer sounding place only has 55"
Some of the catalogue stores still have stock but none available for home delivery.
Think you missed the boat by a week. Seems to be out of stock now.
A site called PRC direct has it in stock for £339I'm always late to the party...lol
I've had the 40" M3300 for about 2 month's, I'm really pleased with it. Was playing Forza horizon 3 today, and it looks great. I cant stand motion blur but it was very playable.
I've tested The Witcher, Project cars, Rise of The tomb Raider and Prey also and they all were super smooth.
Once you get used to the size there's no going back. I've been gaming on a Rog swift for the last 2 years so was worried about the drop to 60hz but its been fine.
Thanks Buddy
Ordered, Will report back when delivered and set up.
Do I need any special leads. I'm running a GTX1070
