No, just the reflection of my financial situation after buying a new house.![]()
Oh well had my hopes up there for a second
Thanks Rossi.@AMDMatt
From elmor:
http://www.mediafire.com/file/w8vh4h2v6v5iaae/CROSSHAIR-VI-HERO-ASUS-1401.zip
Has the SIO -20*c offset for XFR CPUs and some other tweaks. AGESA 1006 still, RC4.
Thanks Rossi.
Have you tried it yet?
I have 2x16GB Hynix Ram, use to have to use 1.49 DRAM boot voltage..
Be interested to know what speed you get that running at (and on what board) ^^Running at 2933Excellent news, I also want to be in the 2x16 clubBe interested to know what speed you get that running at (and on what board) ^^
My g skill is showing CRC OK in typhoon but the lights are still not behaving. Pain in the arse!
What's wrong with them?
it does have a 960 evo 250gb ssd on the board and decent ram though. Cooler is cheap but performance is brilliant and the boards running my ram at 3466 on a beta bios. chips at 3.85 with lowish volts. I havent had time to find its max yet due to work but its solid, stable and a LOT faster than my old 2500k at 4.2
One is in perma rainbow mode. Can't get any control over it. The other goes dark when I fire up the software. I can reset it to rainbow and turn it on and off but not customise it. I have reset to rainbow and disabled the service so now I have two rainbow sticks. Which is better than nothing but annoying.
Semi budget upgrade! I dont care what it looks like inside![]()
damnit dont know how to get the pic to show from imgur!
Running at 2933
From what (little) I know, 16 gig sticks are all dual-ranked, which translates to better performance on Ryzen than single-ranked would be.damnit dont know how to get the pic to show from imgur!
You know, I am becoming skeptical of using occt linpack avx and tpu memtest for testing.
Something about those two tests causes the system to lock up for long periods of time (also experienced by others on oc.net).
Prime95 uses avx and does not cause these lock-ups on small fft's.
And HCI memtest does not cause lock-ups like tpu memtest.
I am sure it was these lockups ultimately responsible for display cut-outs I have epxerienced a lot of (and know someone else has seen this on oc.net), but I suspect that is in combination with nvidia drivers.
Upping the SOC seems to help immensely with display cut-outs. but I am running on 1.2v, which is higher than I'd like.
I've experienced the same, but always rectified with more voltage/higher LLC. Now I never get the intermittent lag/freeze on full load.
HCI, TPU, Prime and RealBench all good for hours.
