Yeah, reality is the biggest enemy of having that comfortable surround sound set room...Hi again. I've been all over the place trying to decide on the right sound set-up for me. I was recently veering towards a full 5.1 speaker set-up, but my home situation has changed, so headphones are the best option again - I'll just have to suck it up re: clamping and hope my noggin/ears do okay with hrtf.
Anyway, I keep coming back to the GSX, for ease of use (have had plenty of problems with sound card drivers over the years), and user reviews from you guys. As I said before, I already have Q701s which won't play well with the GSX. So my options are buy other headphones, or try double amping. So I have some more questions if you guys don't mind.
Would a "neutral" (probably the wrong term) sounding amp like the Meier Audio Jazz do well with the GSX/Q701s combo? Anyone tried anything like that?
If it's a non-runner, I'll go for the HD599s. Either way, I'd need a mic that I can use with the cans. Was thinking of the Modmic. Will it work well with the GSX?
Sound wise Sennheisers shouldn't have anything over 700-serie AKGs so don't see that exactly as sensible path.
And mechanically that one sided attachment of earcup to headband of HD595/8/9 just is anything but structurally optimal design.
(used HD595s before DT990 Beyers...)
Nothing non-working in another amplifier between headphone output and headphones...
Just don't tell output it's driving line in instead of headphones.
Well, actually it will notice that instead of low ohms demanding current it's driving some light 50 kohm load and improves its signal quality because of not being stressed.
If amplifier changes sound in any actually hearable way then it's sure ain't amplifier but distorter, though modern "Hifi" suffers from that phenomenon...
But it doesn't cost arm and leg to have completely neutral and transparent to human hearing sound.
Following actual electric engineering instead of modern "Hifi" BS it's actually rather cheap:
http://epiphany-acoustics.co.uk/pro...plifiers/ehp-o2-portable-headphone-amplifier/
I have myself two Objective2s because of started looking into connecting two headphones to PC.
And tech/science-nerd in me (well, actually read year of electric engineering basics in school) obviously wasn't satisfied to just looking advertising lines.
So found out that lots of multi-output devices had insane output impedances and stuff usually costing awfully lots, while lots of "Hifi" being snake oil.
Ended up buying two DIY kits for 110€ total and doing that fun part of assembling things.
(soldering is fun with temperature controlled soldering station)
One earlier version of ModMic used less sensitive/lower signal capsule, but current versions should work with any semi decent mic-in.
And unidirectional model is definitely good for keeping keyboard sounds etc lower.
