- 18 Feb 2007
- London
Not far off the platinum for this, quite an easy platinum by the looks of it just time consuming, some of the trials are quite difficult.
Believe me, if I can do them, anyone can. The hardest one for me was probably getting the two ravagers and thunderjaw one. But I did it with time to spare after about 5 attempts.![]()
Ah yes done them trials yesterday, found them all ok after a few attempts, the toughest for me was the trials where you need to silent kill the watchers (watch out trial) and the sleight of crate trial, where you need to terablast the crates off the shell walkers, both give you very little time to do it in and the latter has been made more difficult in a recent update.
Yeah, you've got 1:05 to do it and there are two Stalkers near by likely to run into.
the watcher one is the only one i cant get a blazing sun on.![]()
There is good guide that gives you a route to take making things easier.
I used this, still took a few attempts but it worked
What I found with these guides was the AI didn't act the same as other peoples experiences.
Yep forgot about that but you're right... fully buffed up made those trials a breeze.As well as wear that heavy armour shock suit... Oseram Sparkworker.
nice im looking forward to the dlc. any idea on a release date??Yep forgot about that but you're right... fully buffed up made those trials a breeze.
I see the DLC is up for pre-order now.
Really weird - i got a platinum reward email yesterday. But AFAIK i havent platinumed HZD. I havent even completed it yet.
Perhaps a bug?
, I got the platinum yesterday and have not got any email
Sleight trial put me off bothering with platinum to be honest. That time limit is so tight it's mostly down to luck, not my idea of fun.
Think I will still dip back in to get all the figurines and stuff though.
Any news on the DLC release date?
