Hello Guys
Can anyone help
I have a MSI x370 Gaming Plus https://www.msi.com/Motherboard/X370-GAMING-PLUS.html#productFeature-section
I bought corsair CMK16GX4M2B3200C16 16 GB (2 x 8 GB) Vengeance LPX DDR4 (which happens to be v5.39 hynix and single ranked) to go with it
and i'm never hitting my rated speeds dispute 1 official release version and 3 beta version of the bios 1.0.0.6 agesa.
I have tried everything including MSI overlcoking guides.
So i'm giving up and returning the ram.
I'm just about to purchase the Team Group Dark Pro 8pack 3200Mhz 16GB
Does this work well on the MSI x370 Motherboards
K
Hello Guys
Can anyone help
K
Would be even fancier if I could find the fan mounting screws for the rad. Can't for the life of me remember where I put them! Lolvery fancy!
Many months back (early May before AGESA 1006), had written that DR RAM showed more performance on Ryzen CPUs than SR RAM at same speeds, roughly 10% more.
Some called it "anecdotal evidence" and that I was crazy writing it.
Yesterday's AMD blog does a thorough analysis on RAM, timings and optimal settings for better performance using ASUS Crosshair VI and AMD Ryzen 1700 (stock speeds).
https://community.amd.com/community...emory-oc-showdown-frequency-vs-memory-timings
However that's not the whole picture. Manually setting subtimings and the rest of the settings on both SR & DR ram, results to this chart.
Unfortunately they don't have DR ram with manual subtimings.
Also if you see that performance just between 266mhz (3200-3466) that is 10%+ in some cases, the reviewers who still use their March/April charts, with 2333/2400 ram, are way off than just 10%.....
Ryzen 3 is out soon, it will be interesting to see which reviewers redo all their Ryzen results and which ones stick with the old results adding Ryzen 3 results to that and which ones continue to say "oh we only used 2400Mhz Ram on all out Ryzen CPU's because we only used 2400Mhz on our Intel CPU's so that's fair, just ignore the fact that before Ryzen we used 3200Mhz ram on our Intel CPU's"
If they are going to compare overclocked results, and they always do, then they have no excuse not setting the XMP profiles to at least 3200Mhz.
But you can see it right now. Some are testing the SkylakeX with 3200Mhz ram, while the Ryzen CPU numbers are stuck as 3 months ago with 2400/2667 ram
Who are they?
Lets start.
Anandtech.
7900X
http://www.anandtech.com/show/11550...core-i9-7900x-i7-7820x-and-i7-7800x-tested/11
1800X (Ram used running at 2400Mhz on the test)
http://www.anandtech.com/show/11170...review-a-deep-dive-on-1800x-1700x-and-1700/18
Tweaktown is running on the 7900X benchmark, the Ryzen @ 2400 (3000Mhz ram module as with Anandtech), having the 7900X both with 2666 and 2133.
Both have used the same if not worse (Anandtech) numbers on the 7900X benchmark compared to the April review.
Can go through Guru3d etc, but after I come back from the cinema.
Corsair Vengeance Pro DDR4-2666 4x8 GB.
Or G.Skill Ripjaws 4 DDR4-2666 C15 4x8GB.
Or TeamGroup NightHawk RGB DDR4-3000.
Following on my previous post I think I have a good chip, or I've missed something. (Entirely possible)
I was rather put off by the technical shennigans people were going through. All I did was increase the multiplier (by steps) with volts at Auto. DOCP 3200 for the RAM.
I had to boost the fan profile a little, but I have 3.9 under a H105 never breaks 75c on test and 62c with handbrake.
Cinebench gives 1712.
Does this sound OK ?
OK Thanks - what is AVX ?
