I mean look at that, they are pretending different ram from different vendors running at different speeds are all the same in performance results, of course every noob knows they are not, especially not when it comes to Ryzen.
so I've just turned on my ryzen r5 1600 build and it's gotten to the desktop ok - nothing's blown up or died......yet.
I see people talking about ryzen power plans etc. where do I go to download those (windows seemed to install a few bits and pieces - os drive came out of an intel build) or where do I look for that? and anything else I need to download to check all is running as it should - only running stock at the minute so not needing any stress testing tools just yet
From the AMD Gaming blog, it's now part of the AMD chipset drivers. Google those and the power plan comes with it. Just installed them myself.
https://community.amd.com/community/gaming/blog/2017/04/06/amd-ryzen-community-update-3
Or else you go to the Windows power options and set everything to maximum which is better imho![]()
cheers chaps. question though, don't loaded the chipset drivers from the link above but still can't find the ryzen power plan option in windows?!
for anyone using a gigabyte motherboard (stock) check your vcore mine out the box was 1.5V and 1.490V stock... pretty shocking...
its now 1.116V
Nope, 1.234 here @ stock on auto
1.380v @ 3.9 on auto
Seriously Smogsy, sounds as you have a bugged board/bios going on the issues you have in the other thread + this high voltage @ stock
Edit:
@Panos
Sure either me or someone had posted that a while back
it was 1.268V in games /idle but if you monitored it over long peroids at 100% load (was rendering it slowly creeped to 1.5VNope, 1.234 here @ stock on auto
Edit:
@Panos
my point is its not a short period of time it stays their as long as i'm at 100% on all cores. highest i've seen was 1.568VThat's what it's meant to do. The 1.5V will be when it's boosting on a single thread for short periods of time.
In the usual Windows power plan screen? Yup, rebooted and nowhere to be seen. I'll have another go later today.Should be there. Did you reboot ?
Also many tools are reporting the wrong voltages and temps. I'm using hwinfo64 which I believe gives correct data.
But you need to install chipset drivers and there is option to install power planIn the usual Windows power plan screen? Yup, rebooted and nowhere to be seen. I'll have another go later today.
Cheers.
I did install the chipset drivers but I think I chose express install. Guess I have to do a custom install?But you need to install chipset drivers and there is option to install power plan
Yeah, Try custom, ryzen profile is as a separate thing to tick during installation. Not sure if it gets installed with express.I did install the chipset drivers but I think I chose express install. Guess I have to do a custom install?
