Interestingly there are no 1000 or 1100 series SKUs.  I wonder if that means AMD will have a 2C/4T set of SKUs.
			I hope not, let that product segment die off for mainstream desktop. I'm sure the demand for 2c4t could be adequately serviced by the Zen APU.
			lol
Pointless chip would die 13 years later.
Yet the fact of the matter there is no 1000 or 1100 series SKU - the rumours pointed to the 4C model starting at 1100,not 1200,and they are all above £100.
I am not sure why you think it is pointless - AMD has no new chips between £50 to £100 at all,and if the 1000 or 1100 chips were quad cores,AMD would be launching them this month as lower clockspeed chips.
Also,where have I mentioned a Ryzen CPU salvage?
This means another SKU is being launched later in the year to fill the sub £100 area so it probably isn't based on the current chips,and how do you know whether the first Zen APUs are not smaller 2C/4T chips in the first place,or even AMD having multiple dies for different market segments??
If you look at Bristol Ridge and Stony Ridge,they are actually two separate chips - 4C BR is around 250MM2 and 2C SR around 125MM2.
If they do the same with Raven Ridge,there is probably going to be different SKUs.
Remember,one area AMD is massively under represented in ultrabooks,which are all 2C/4T since they are designed for very low TDPs - can you imagine how tiny such a chip would be with even a decent IGP,and cheap it would be to make??
Even with a reasonable IGP,you will be probably looking at something sub 100MM2,and probably sipping power,and with a better IGP than the Intel CPUs and supporting higher speed RAM too.
Selling a 193MM2 chip for under £100 seems a waste of time for AMD,especially if Ryzen has such great yields and those low end chips are probably more likely to be sold in cheapo PCs too which need an IGP.
Intel also has worse SMT too compared to AMD,and the Pentiums have various features shut off too.Intel also locks the chips under £100 and will have a far worse IGP for gaming.
Plus what upgrade path has Intel got?? Even a £65 B350 motherboard can have a Ryzen 5 1600 in it fine!!
If anything I also think the Ryzen 3 range and lower end Ryzen 5 range won't be very long lived.
I expect AMD will have a larger die APU which will replace that range upto the 1500X with a decent IGP.
