Why did they make the FE look so nice and yet the RX Vega look so meh?
Cost, hopefully.
Yep cheers, thats the plan, but i can feel myself turning green soon .... both in an angry and expensive way ..
What you mean the "founders edition" thats just a reference card with an extra £100 slapped onto it just because they renamed it?
Think he means the AMD Frontier Edition shroud.
Typically, and straight from the mouth of AMD, pro drivers do not update as frequently as consumer drivers. When the updates happen, the pro drivers will receive all the same game-level optimizations as the consumer drivers. Let’s say you’re running the pro drivers and Battlefield 6 launches: Those pro drivers don’t need an update (the professional applications haven’t changed), and so don’t receive one on game launch. The drivers are unoptimized for this fictional game. Consumer drivers have launched, though, to support the new title. Going forward, AMD hopes to leverage its toggle switch to permit the user to fetch those consumer drivers for playing the latest games. At a later date, maybe when AutoCAD updates, the professional drivers will eventually launch and include the game optimizations.
there was a difference though.3 preferred the AMD system and 1 Preferred the Nvidia system. The other 6 couldn't really tell the difference.
Do we know if Top Vega will be Reference Design only or will we have aftermarket fan designs available as well?
I hope so especially if its as hot and power hungry as it looks...Can't see why not, fury x was a special case, id say there will be for these cards.
So again another case,of you supporting your mates in an AMD *Snip*
You sure you won't be buying one or two Vega's Loadsa?Well i posted a chart earlier in the thread, showed the XTX (AIO cooled) and XT (Air cooled XTX) were ref only, so AMDs AIO and Crappy blower, only The cut-down XL was coming custom cooled.
Wether its true or not, pass.![]()
You sure you won't be buying one or two Vega's Loadsa?![]()
It wasn't reviewed, it was just the blind test using an engineering sample. AMD took it away at the end of the day.Are we even sure [H] had up to date drivers? It wouldn't be the first time that AMD have held back drivers until launch day and then sent them to reviewers. It annoys the reviewers no end, but it does stop any leaks. Of course, you also end up with lots of initial reviews done on non-launch drivers that stick around and haunt AMD, but that's par for the course for AMD.
If AMD uses the Pepsi challenge format to obfuscate Vega RX's performance, it could be because they don't want people benchmarking because they haven't given out the launch drivers to any reviewer, and have no intention of doing so until the launch. They want the reviews out between launch and ship time, they want them on the correct drivers, because AMD still are still hiding everything about the performance.
That would explain why Kyle's "exclusive" was so restricted and limited. AMD don't want anyone actually testing yet.
He did say he wiped the OS's and installed the drivers, so pretty sure it was all above board in that respect. Not a bad test either but I wouldn't buy my gear on the basis of 'blind testing' in one game but at least the test had the majority liking the AMD system more than I was expecting but the blind test was a bit naff in terms of one game and VA Vs IPS.Are we even sure [H] had up to date drivers? It wouldn't be the first time that AMD have held back drivers until launch day and then sent them to reviewers. It annoys the reviewers no end, but it does stop any leaks. Of course, you also end up with lots of initial reviews done on non-launch drivers that stick around and haunt AMD, but that's par for the course for AMD.
Just the bit about trying to make the monitors look the same doesn't sit well with me.He did say he wiped the OS's and installed the drivers, so pretty sure it was all above board in that respect. Not a bad test either but I wouldn't buy my gear on the basis of 'blind testing' in one game but at least the test had the majority liking the AMD system more than I was expecting but the blind test was a bit naff in terms of one game and VA Vs IPS.
