Sorry, edited above, I meant to say the standard 64..
my bad!If it works then cool, I can always OC down the line with a beefier PSU etc..just its too much money from the get go all in one..for me anyway...
my bad!Check the reviews. PCper are good in that they just measure the draw of the card. The Vega FEs pretty much matched their TDP so I'd expect Vega 64 to be similar.my bad!
If the 56 can just match a 1070 Will stick to my 980tis, they can match a 1070 most of the time from reading benchmarks etc.
Easilly the best vfm card right now even if i did buy them at full price theyve been well worth the money.
sold my hybrid 980ti for 360 today was fantastic card. Best card i owned EVER !!! Well ebsides black screen driver crash random in WoW that is.If the 56 can just match a 1070 Will stick to my 980tis, they can match a 1070 most of the time from reading benchmarks etc.
Unless you need the upgrade from Fury in any amount, it doesnt seem a great leap forward to bother especially jumping on release day for it. [The other side is Fury isnt selling for tons like a 480, but 480 to Vega seems good idea to me]
Ask again in a week or In Sept or October if its possible to wait and get some smarter version for the same price? seems the better course. Or even wait till xmas depends on your patience/requirements and hope the whole deal develops, it will be attractive if they do improve drivers but even after NDA goes that part is all a guess
a bit hypothetical here but...
if Nv and AMD's top cards both performed exactly the same in every way shape or form, same price/temps/design/power usage/fps/warranty etc...
which would you buy?
Coolermaster V700 will it be enough for the AIO Vegan ?
Are you planning to overclock it and do you overclock your cpu?Anyone ?
i get the feeling my EVGA G2 650w aint gonna cut it??![]()
Vega 56 definitely isn't a worthwhile upgrade form a 980ti.
I was starting to worry i only just bought a Corsair RM650X lol
Depending on the manufacturing date some of those monitors ARE capable according to reviews/forums (although BenQ doesn't mention it for some reason).
Have you tried enabling it?
Initially the 64, maybe the 56 if its good price performance, however if its silly money i'll go for a 1080, might even stretch for that gigabyte black 1080tiWhich Vega are you interested in? The dollar price is ok, but, that doesn't always mean the UK price will be good.
