- 25 Nov 2005
Are you planning to overclock it and do you overclock your cpu?
Unsure depends how good they are and how much extra heat an OC will produce and 4770k with a slight OC to 3.9 (used to have it higher but I started getting random bsods so reset it and left it to use intels auto boost setting)
It's a gold rated PSU. It got great reviews. It should be fine. If you bought it on release, nearly 5 years ago, I would just check and make sure the fans are ok.
Ok thanks
