VEGA 64 UK PRICES
Status
Not open for further replies.
Caporegime
18 Oct 2002
Ireland
Where's all this guff about it being good for mining coming from? People have already tested the FE version for mining and it's cack :/
Gibbo oddly enough, he said it was info from someone at one of the oem's, then later said it could be bs. Of course the original info spread across tech sites (thanks to some on here) and the statement of it being possible bs didn't.
17 Jun 2012
So I wonder what magic is in a gaming Vega that isn't in the FE card, that magically bumps it up from a pathetic 30-32 hashrate with 300w+ consumption.
Caporegime
18 Oct 2002
Ireland
Supposedly something to do with the gaming drivers that will be released alongside the RX cards. At this point it looks like bs though.
12 Feb 2009
That would be my guess also. Maybe over 40MH/s with the right tweaks (both from AMD and developer). Probably an attempt by the manufacturer to get miners interested and snap them up before seeing the real performance(if they were close to 100MH/s getting one on day one would be every miner's top priority).
Yes I suspect this is the case. There's nothing in the spec that suggests the high eth rate.
I've seen the Reddit post for the supposed "Professional mining software developer" And the basic reasoning given looks like complete garbage. The combination of clock speed and bandwidth are the limiting factor.
If it was just bandwidth the Fury and 1080ti would be hitting 60+ MH/s already.
Unless there's something different with HBM2 with new drivers, the clock speed and bandwidth don't suggest any more speed than 35-40 MH/s.
31 Oct 2002
Remember that the limited edition Vega 64's (metal shroud versions) will also come with two AAA games, Prey and Wolfenstein 2, assuming you were going to be buying them anyway, that's £80 off the bill right there :)
I'm also hoping the $100 discount on Ryzen CPU/Motherboards is included, as I want to build another Ryzen system for a family member soon.
17 Jun 2012
HBM isn't much good for mining anyway judging by Fury.
Whilst 35-40 mh/s isn't terrible, it is when you take into account the insane power consumption. The extra electricity cost will offset any gains over a 580 at 32-33 mh/s and 100w.
12 Feb 2009
Though Giibbo's post didn't specificity mention an algorithm, everyone assumed it was eth. :)
1 Apr 2010
Cant see how your getting £80, Prey is £20 on cdkeys and wolfenstein is about £26.
31 Oct 2002
True, I was looking at Steam prices. If you do buy from those third party marketplaces, it reduces the value to £46, so still worth considering :)
How reliable is that CDkeys website? I've used G2A in the past which seemed decent enough.
16 Feb 2009
Still time to take it back!
Were you aware of Vega price/performance before buying?
I was not. I just assumed that due to Ryzen being good and all the hype that VEGA would be too. If it's £400-500 for 1080 performance I'll probably get it just because it's newer technology, otherwise I'll be eyeing up the 1080Ti as I now have a new job that pays pretty well, certainly more than double the cash in hand each month as my previous job.
1 Apr 2010
Its one of the most popular key-sites and very reliable.
29 Aug 2013
CDkeys is great, been using them for years. Even for new games they are way cheaper than steam, usually £25-30ish
27 Sep 2015
hahaha headhunt NVIDIAS market rep they said, not budget anymore they said
good luck with that revenue at these prices "I" won't be buying for sure
Status
