I've watched Grand Designs you can build a whole house with nothing more than YouTube and hope!
And some witty analogies from Kevin. Those are essential and provide solid foundations.
So he didn't do the roof himself then? Various other skilled tradesmen did the skilled part of the job for him!
What about those tradesmen that think they can build a decent home network etc, no bother if they watch youtube?
I once had a debate with a nurse about who she considered smarter - the consultant using an MRI scanner or the engineer fixing the MRI scanner.
She chose the operator. Yet the engineer would be qualified and trained to dismantle and re-rebuild that machine, he would be required to know how to operate and what imagery to expect for fault finding and what adjustments he could make would affect the output. It would have been an engineer that would have written the training manual/taught the operator.
By that logic the people who built the tools that the engineer is using (multimeter, screwdriver, etc) are smarter than the engineer because that engineer is simply the operator of those tools.
I dont think you can infer intelligence based on the different things people have learned to do. The engineer may be smarter, or the consultant may be smarter - there's no way to tell in your scenario.
But trades people are being paid by the hour. You're paying them to do it fast, do it well and probably cheap... and I'm sure someone has posted the triangular diagram of that many times before...Someone doing it themselves can spend longer on a job to get to the same standard as the person doing it as a job, because they aren't getting paid by the hour/job.
Good enough that other people would pay you good money to do the same for them and good enough (in your judgement, maybe) that you will happily put a legally binding guarantee on your workmanship, I suppose... Kinda how I would assess a tradesman that I was considering hiring myself.What do you define as a "professional" standard?
Is that what actually happened, or just what it says in the brochure from the developer who is flogging you these ¾ million Pound properties?I've been looking at a fair number of (eq) £600k - £800k new build houses recently and a lot of them have a a fair amount of work in them that is frankly shocking. All done by "professionals" to presumably a "professional" standard.
And again, that triangle of Fast-Well-Cheap comes in... assuming they are actual professionals, not utter cowboys.Yes, many of those "professionals" may well be able to do a better job if they were given the time/money, but that goes back to the point in my previous post.
I'd argue they are.Like many things, being able to do something to a good standard and doing it as a job are not mutually exclusive.
Very much so. But it's a rare person whose personal standards and requirements are higher than thiose expected of a professional.That extends to IT, banking and a multitude of other industries/trades as well as building trades.
I believe in my particular context, I was referring to the poster equating his half-day of looking on the internet and maybe trialling it a couple of times beforehand, to a skilled tradesman with a decade or two of experience.Just claiming that if you don't do something professionally means you're going to do something to a low standard is generally wrong tbh.
Not sure what's going on here, but it sounds like the two guys are actually one.The guy loading the timber into the CNC may like to consider himself a trade I guess, would probably up his wage but pushing planks into a hopper doesn't require and skills I am afraid, nor does slecting the drawing so the machine knows exactly what to cut. The guy who pulls the pre cut pieces of timber out of the hopper lays them out to the spec and uses those connector thingies (no idea what the technical names is) would probably also like to say hes a trade.
https://en.wikipedia.org/wiki/TradesmanIf the definition of trade is someone who does something even the guy in the local car wash is a trade.
Some trades, perhaps, but only to a certain extent.By far the biggest advantage trades normally have over a competent diyer is the tools.
Indeed, but it's even more amazing how much more of a difference the right techniques make.Its amazing how much difference using trade quality tools will make.
Stop hiring poor tradesmen, then!!I'm still fixing the mistakes and poor quality the trades did in my house.
"Let's read the words, the words, the words, the words.... from the developer!!!"![]()
Most of the complaints seem to come either from those who hired cowboys, or who don't like the fact that proper professional quality isn't cheap.
I'd argue they are.
DIYing it so you're happy, however good a job you do in whatever time, is your own standard.
Doing it as a job is to someone else's standard and timescale.
Whoever first said, "Oh, that'll do" probably gave birth to the DIY culture at that point!
Stop hiring poor tradesmen, then!!![]()
They will if you pay them enough....A builder is not going to spend hours over one small detail, a homeowner doing it themselves may.
Yes, very much so. In terms of their standards, at least.So a fair number of tradespeople aren't professional then as their quality isn't good enough, whereas a fair number of amateurs could well consider themselves professional by your definition.![]()
So?The point is they aren't £100k starter homes where you could consider cutting corners to save costs as a legitimate option.
Depends on the trade - I'd generally argue that things are not just things and the better you do the basic things, the more likely the finish will be easier, better and of higher quality.But then how often does that happen outside of multimillion £ contracts, and how often does that need to happen? Running cable is running cable, framing is framing, it's only really when you get to the finish that that's more relevant, such as tiling, painting, cabinetry etc, but again how often does that happen in your average residential work?
In principle and in general, yes, your average professional will be better.I'm disputing your claim about "amateurs" vs "professionals" in general and that your average professional is going to provide a better final product than all non professionals.).
And I am in agreement.it's the other parts of doing it as a job that as well, the interacting with customers, doing it to the standard required in the time required etc. It's what I pointed out in an earlier post.
They're not professionals, though, they're the cowboys... In the uncommon cases who are actual professionals, as discussed above, if your standards are higher than even them, you are now into the flying pig realms of being unrealistic or not understanding the limitations of the material/substance/whatever and "can ******* well go do it yourself, then" as the professionals would be walking away at this point!!I, and most of the people in this thread must be those rare people then.![]()
It's what I was prodding at in this specific instance, yeah.So that's one of the caveats then.![]()
In some trades, yes, because there's a lot of work and it's easy to blag it. But that doesn't mean the average amateur is especially good, either. Same for driving, really - Just because a bunch of people ar utter cack at it, doesn't mean someone who meets the basic standard is awesome.That's the problem, there are apparently a lot of poor tradesmen around.![]()
Technically I do qualify as a tradesperson, I guess. Somewhere between the Construction and Service branches, with fingers in both and several CITB type qualifications covering it.... not that I'd really refer to it as such. I've always regarded a Trade as more like a Craft, while I'm more toward the Engineering side.you may be a really good one, in which case I'm sure you go to a lot of jobs and complain about the poor quality of previous work.
If you're THAT good that you'd put a guarantee on your workmanship and own up to it if the work then failed, then yeah that is professional.
So?
Money is money and if a developer can save cash by hiring in cheap workers who can bodge it to make them more profit, it's perfectly legitimate as far as they are concerned. Having fancy features doesn't mean the only people in the game are good, honest, hard working rich folk... In fact, chances are the people buying such fancy frippery in their houses have money to burn and don't care what it costs, perhaps even expect it to cost a fortune, so are just rich idiots ripe for the fleecing... It's all in your Rogue Traders handbook.![]()
There is some variance between trades and in some of them your average professional will be FAR better, because it takes more skill to do even the basics.
In other trades it will not, because it takes less skill and it is more widely accessible, meaning you get more cowboys able to spin a fast buck (or thousand) before ******* off with your hard-earned. I'd say it's fair that it's more common in the Building trades, as a little knowledge and experience allows you to blag it a long way.
A good number of them are former DIYers/amateurs who realised there was profit to be made - That's exactly how I ended up in Reading, in fact. A mate and I started a property maintenance business, with the express aim of delivering a professional service and with each of us specialising in different areas. Downside is we were undercut by the seasonal influx of amateurs-turned-'professional' cowboys and we never got the business up to profit. All we were left with was the satisfaction of seeing the customers who turned us down and the trainwrecks that now adorn their homes!
They're not professionals, though, they're the cowboys... In the uncommon cases who are actual professionals, as discussed above, if your standards are higher than even them, you are now into the flying pig realms of being unrealistic or not understanding the limitations of the material/substance/whatever and "can ******* well go do it yourself, then" as the professionals would be walking away at this point!!![]()
But yes, we do complain about the previous work, mainly because they only call us when the previous work has failed and I can tell which bunch of cowboys did it based on the modes of failure!!
Actually, the more I think about it, the more born-awesome I start to sound...![]()
I don't think architects would class themselves as a trade personally, they would class themselves as a professional in my opinion/experience
The guy who owns the factory producing roofing beams to order wouldn't classify himself as a trade, but an entrepreneur
The guy who pulls the pre cut pieces of timber out of the hopper lays them out to the spec and uses those connector thingies (no idea what the technical names is) would probably also like to say hes a trade. The reality is the bottom 2 are factory workers.
So no trades were present at any point.
Its almost as if there is a generally accepted list of trades, and what they are
https://en.wikipedia.org/wiki/List_of_construction_trades
I am struggling to see architect, business owner, factory operators on there...
Fair point. So it comes down to how other people deem skills they don't possess easy to learn and how the skills they do have hard to learn.
Although in your eyes a CNC operator 'only' pushes planks into a hopper and is deemed in your eyes to have no skills - by definition he does. https://en.m.wikipedia.org/wiki/Skill
The fact is you don't think those skills are as difficult to learn than yours.
Back onto trademens, I'd like to see you to quote for an install of a three phase distribution system to include the supply of complex lighting circuits and numerous ring mains - in what the regs deem as a special location. If you can do that in half a day of internet learning from no previous experience then I bow down to you. That is without any of the 'rule of thumb' lark that is quoted on the internet but correctly calculated cable calculations, breaker sizing calculations etc. Give me four years and I can do it, half a day...
Yesterday I had a landlord call me about a faulty socket in the kitchen.
He uses a different electrician for his remedial work but as I am a friend of a friend he decided to give me a call.
The previous electrician had diagnosed an "earth fault" in the kitchen and decided to split the ring whilst leaving both sides of the, now radial, circuit on the 32A breaker. He said it was a temporary measure whilst the landlord would need to have a new ring main installed for the house.
So I turn up with my tools and tester. Open up the socket and find an earth fault, but it needs to be chased round the circuit. I eventually found the culprit was simply a very old socket in the hallway that had fused over. Replacing the old socket and conducting Insulation Resistance and Continuity tests I found the fault to be completely cured.
Not bad for 60 minutes work and a damn sight less expensive than rewiring the house.
There are good tradesmen and there are crap ones. Don't let your experience with the latter cloud your judgement towards the former
