Cool so like the incursions in division then.
Are the point of them to get better guns to use in mp?
I'll try to cover some general points for those who didn't play D1.
In theory, yes they are like Incursions. In practice they are
much better put together than any incursion in TD. In D1, they generally consisted of working your way though 3 or 4 smaller boss encounters with a final end boss. There are unique mechanics required for each boss/phase, major focus is on team work and communication as players will be singled out or need to pair up etc. In between each encounter there are normally mazes, jumping puzzles, hidden loot chests etc.
Apart from the initial starting areas, the raid settings are completely unique (i.e. you will never see them in game unless you enter the raid) and in fairness to Bungie they are normally an epic journey, not just sat in one room as per Falcon Lost etc.
Later in D1 they also added challenge modes (which are theorised to be Prestige mode in D2) whereby for each raid encounter, there would be a very specific way of completing it e.g. every player has to take a debuff once, or you have to stop the boss teleporting around the map etc. These challenge modes would give higher drop rates, and unique shaders/emblems etc.
As far as loot goes, its slightly similar to TD, raids drop "gearsets" and have a higher chance to drop exotics. There are also unique quests unlocked when completing the raids.
Very interesting read here for the Outbreak Prime exotic, which shows the depth that some of the raids/quests go into both in and out of the game, far more complex than just a standard loot drop from a boss.
For PvP, weapon damage is usually normalised, so if you're a newbie at level 10 you don't get one shot by a level 20 + max power player. However, there are various monthly and weekly events that do have "power level" enabled matchmaking, where having the best gear in the game really comes into play. These activities again drop unique gearsets and weapons only available in those playlists/gametypes. Hope that helps
