Thanks gents, will take a look at both
Wash and a coat of wax today. Collonite 476. Forgot what a cow it is to apply :/
You're doing something wrong. I've always found it easy to apply, especially if you've polished recently.Wash and a coat of wax today. Collonite 476. Forgot what a cow it is to apply :/
Most people try and put far too much on. You should barely see it when applied and it should dry to a slight haze. More than a slight haze and you're using too much. I do a couple of very light coats per panel.
You also need to apply it with a slightly damp cloth or polishing sponge. This makes a huge difference to the ease of application. Collinite wax is very solid which means it lasts ages and goes very far, but there's very little moisture in it which makes it hard to apply so a damp sponge makes it much easier.
Used a clay bar for the first time, the meguiar one that comes with their detailer.
Obviously most of the muck was on the lower panels! I ran into some rough patches near the rear bumper towards the left though where the clay bar didn't help. Is this because of damage to the paint? Will a more aggressive clay bar do the trick?
The plan is to eventually machine polish using a DA
Well I only had a few scruffs repaired recently, so could be repair damage but doesn't look like it. If so I might as well have repainted the whole bumper!Could be either road muck coming up under the car (i.e. makes the rear dirty), or the bumper has repair damage?
Hello folks, looking for something to seriously matte the finish our our dash. Picked up a dashcam and half the screen is taken up with the reflection of the dashboard (very sloped windscreen doesn't help) so i need to get rid of the dealer valet blind-o-gleam crap on the top of the dashboard.
Anything in particular to look for or is the matte finish stuff all pretty much the same?
Thanks.
Thanks.
I forgot how good Sonax brilliant shine detailer is. Washed the car yesterday, but it got dirty on the motorway again today - rinsed it with the hose and it is shining again. Leaves a decent finish too versus how quick it is to apply.
