- 11 Jun 2013
A couple of "independent" reviews worth a look
Nope was looking at the Evolution I think it was?
There doesn't seem to be anything at a similar price without a bar between your legs that I can see?
Only 3 weeks to go...
What are some of the issues?Unfortunately it still has many issues it could use three more months not three weeks.
It's Project Cars. That's the issue.What are some of the issues?
The big one for me is AI, getting rammed on the straights by AI cars overtaking is not cool.What are some of the issues?
They also brake much later in the corners punting you off and if they do manage to get past then they stand on the brakes mid corner so you run in the back of them.
Large pile ups on the first lap mostly first corner, also corner cutting by AI.
Game save setup is a confusing mess and half the time doesn't work.
End qualifying early and AI set impossible times.
Having to go into the hud menu and save the virtual mirror every session or you won't have it in cockpit view.
lack of random start lights allowing anticipation and ramming as in pC1.
It is overall more stable in fact I've had no pc crashes for months and they seem to have just fixed the constant tire smoke in corners.
