- 5 Sep 2011
- Surrey
Ian already came forward to confirm they weren't earlier in the thread
What do you use to glue the IHS back down with?
I was thinking more of installing and uninstalling the cooler, would the IHS not move around and/or get stuck to the cooler? I'd be inclined to secure it first, so hence the question.
It's secured by the retention plate - it can't move.
What material should one use to prevent the components inside the IHS to become in contact with the liquid metal? I've never delidded anything, so I don't know if liquid metal will be the only paste that brings dramatic improvements? Or is it also necessary to scrape the glue off the IHS and PCB?
Thanks![]()
And yes, you should be removing all traces of the IHS glue/silicone.
Is that possible with the SKL-X CPU, as I thought it wasn't advisable?
It's certainly difficult due to the close proximity of surface mount components, but if you want the best temps, that's what you need to do.
It's why id rather pay someone to do it for me...![]()
But it would make for the most humongous Epeen though.
It'd be a bit like owning a Porsche though. You think you look cool, but every else looks at you as thinks "what a *******!".
