Strong winds from the west here the last couple of days, have been tempted to head out for a segment effort or two but with the rain showers also around I've headed for shelter instead! Dry all day today again with the winds and I've woken up with my shoulder f%%ked and can barely turn my head. Need to rest it later rather than jumping on the turbo as I'd planned, gah! Really want to get an FTP test done for a result before I lose much fitness (summer riding is over, all big weekend planned rides are done & baby about to arrive). Might be a task for the weekend if I don't head out in the rain for any group rides...
Giving segment ninja a look Steve, thanks
Knee warmers last couple of mornings :'( Very sad times! This wind is brutal at the moment, hopefully back end of the month will be better as I've got a week off.
Have been wearing knee warmers for months! Basically any temperatures below 17 degrees really... So most mornings, even in the summer! I do have varying thickness of them though (and I generally wear them more than leg warmers due to short leg syndrome)!
Full fingered gloves are the same but I have 6 pairs of varying thickness (2 deep winter, 2 spring/autumn, 2 light ones), whereas I only have 3 pairs of fingerless (1 'good', 1 commuting & 1 random pair).
Have actually worn 'winter shorts' (thermal, windproof) the last couple of days and a thicker windproof jersey today. Cooked slightly at lunch yesterday as it wasn't as cold+windy as forecast!
Set a new record today
...for time taken to fix a flat at the side of the road
Haha, how annoying! At least you know about it before being stuck in the snow/sleet/hail at some point.
The removable head on my old pump was similar, it'd bleed air unless done up stupidly tight but being plastic screwed onto metal it'd gradually work loose from vibration being carried on the frame. After the first couple of times I used plumbers tape & mole grips to get it majorly sealed on there (figured I'd never need it for a schrader valve).
