The RX Vega 56 Owners Thread
I got 4239 and my card boosted to 1550mhz on v64 bios.
Hmm, strange only on this benchmark @ 1080p extreme my card doesn't boost.
Since you're on 64 bios, I guess that wouldn't be same as mine on default 56 bios.
I'm going to test using default setting and see if it boosts instead of the undervolt etc.
Tried custom, same results. Thanks
Found the fix! Just change ur core mv to 1030 and it should boost normal, tested on the v56 bios. Managed to score higher than the 64 bios for some reason, got 4463, mem was 920 clock was 1530 at 1030mv
Just tried and still same. I tried on default vaults and I ended up getting around 1480mhz. Strange thing with this demo is I only get higher clocks with default volts :S
My Vega56 installed (Needs a bit of a dust i know :o)
The club, the club, I is in the club ;)
Welcome and on TROH.:)
The Roll of Honour.
Date 15/09/2017, Make Reference Air, Jazz2k, Link
Date 15/09/2017, Make Reference Air, lowdog, Link
Date 13/09/2017, Make Reference Air, Evilmethod666, Link
Date 07/09/2017, Make Reference Air, jimhaumman, Link
Date 05/09/2017, Make Reference Air, FiremanSam, Link
Date 03/09/2017, Make Reference Air, erazor51, Link
Date 03/09/2017, Make Reference Air, Angst, Link
Date 01/09/2017, Make Reference Air, solarp, Link
Date 01/09/2017, Make Reference Air, slunge, Link
Date 01/09/2017, Make Reference Air, Narrack, Link
Date 01/09/2017, Make Reference Air, Daiyus, Link
Date 31/08/2017, Make Reference Air, icey_haj, Link
Date 31/08/2017, Make Reference Air, Vince, Link
Date 31/08/2017, Make Reference Air, sideways14a, Link
Date 31/08/2017, Make Reference Air, MagicBoy, Link
Date 31/08/2017, Make Reference Air, Roob65, Link
Date 31/08/2017, Make Reference Air, sjones1404, Link
Date 29/08/2017, Make Reference Air, bells, Link
Date 29/08/2017, Make Reference Air, Sybra, Link
Date 29/08/2017, Make Reference Air, docsonic, Link
Date 29/08/2017, Make Reference Air, Disjunto, Link
Date 29/08/2017, Make Reference Air, old gamer, Link
Date 29/08/2017, Make Reference Air, FelixB, Link
Date 29/08/2017, Make Reference Air, megatron, Link
To get on the Roll of Honour all you have to do is post a pic with your user name on it of your Vega 56.
Just ran Superposition 1080p extreme on my 56 with 64 bios.
I got 4022 with card set at 1700mhz and 1100mhz HBM. Seemed to maintain a boost of between 1650 and 1680mhz.
4022 seems a little low. I get over 7600 gpu score in Timespy
