No, mine is running on ESXi 6.5 so works without any changes... I'm using the 1.02 loader but I don't want to update as I could loose all the data and I cannot be bothered to back up (or download from my crashplan backup remotely).
			You'll have to buy the plugin... anything passed through or plugged in to DSM directly will not be read without it.Can Xpenology running on a Microserver read ex-fat formatted flash drives/SD cards or do you need to buy the in-DSM package like you do on the standard Synology kit??
There is a thread on the main forums showing how to just wipe the os partition data from each drive, allowing you to create the partitions and reinstall a version that you want.... Can't verify the actual performance but I know others have stuffed up and fixed it.
That could work, install the OS on to a new drive, install the old ones once you have a volume created and then repair the dsm installation on the older drives thus leaving them at parity with hte new drive... after which you can pull the new hdd out if you want.
 having a look for that post in the main forum you mentioned. Almost at the I've spent to much time phase and might as well just start again.To be honest if you're not going to use a spanned pooling system, such as mdadm that synology uses for its raid system, you'll be better off using unraid in my opinion. Windows and drivepool is great, except there is no parity built in and you have to use parity addons which are not that easy or effective to use.
Unraid has a couple of advantages; it doesn't span the data so each drive is self contained and can be pulled and read on any other machine, it is a product rather than a hack so support is there and its designed to run on any hardware, has a built in hypervisor for running VMs within the unit, supports docker ... main drawbacks are speed as you're confined to a single device streaming data rather than multiple drives at the same time, parity is contained on a separate dedicated hdd so speed can be more limited depending on the device, doesn't have iSCSI support.Well I've given up trying to recover the data. Looks like i'll be ripping my DVDs again. Currently have 3 x 3tb drives and want a bit of redundancy in case one dies. Got xpenology 6.1 up and running now, would i gain much by going unraid?
