- 11 Mar 2013
Until then you are a raging AMD fanboy with no actual AMD hardware.....
Finally someone says it. Thank you.
His AMD fanboyism is doing my head in.
@gavinh87 If only it was smoother, my old 4.7Ghz 2600K had better frametimes in most games.
Okay.... this just got real personal.
Already been covered a little further back.
Do you even have a Ryzen?
Everyone here should, really.He enjoys the process of forum debating.
+1
If you don't like talking and debating then you is in totally the wrong place.
Which means the 8700K + mobo could be over £160 more expensive than the Ryzen 1700 + mobo?
That's not true. Is Broadwel level, so 10% stronger than Haswell and just 1.5% weaker than Skylake.
1700 goes for £275 these days, a good mobo for overclocking around £80 (B350) and comes with an adequate cooler for 3.8-3.9 overclock.
8700K alone will go for £350-360. + motherboard ~150 + cooler.
That's still about the same cost.
