- 7 Dec 2015
How is £350 about the same as £500-550??
3400C14 DIMM modules are about £160 more expensive.
3.8/3.9 on the stock cooler is not advisable.
I assume you have tried this?
Coffee Lake pricing leaks at UK retailer
Taken from OC3D news
Intel 8th Generation Z370 Coffee Lake CPUs
- Core i3-8350K £174.35 (4 cores, 4 threads)
- Core i5-8600K £250.50 (6 cores, 6 threads)
- Core i7-8700K £353.86 (6 cores, 12 Threads)
Intel 7th Generation Z270 Kaby Lake CPUs
- Core i3-7350K £135.05 (2 cores, 4 threads)
- Core i5-7600K £213.18 (4 cores, 4 threads)
- Core i7-7700K £310.58 (4 cores, 8 Threads)
If these prices are correct, Intel is offering their 6-core, 12-thread i7 8700K with pricing that is slightly higher than their 6-core, 12-thread i7 7800X, which makes sense given the fact that the 8700K is expected to feature higher base/boost clock speeds, especially in single-threaded workloads
Guess Intel isn't worried about Ryzen with these prices. It's making me think twice.
Google search. And find overclocks using P-states, not those who put 1.4v on the CPU and let it run.
That chart makes no sense, all the Ryzen stuff should be the same
It's the ryzen 3 I'm on about, a pretty big difference. But fair point. I was drunk anyway.Cache sizes and memory bandwidth does differ. Its why 1200/1300X are behind.
Also 1 point here or there isnt that big of a margin. Might ve even smaller than 1 point without rounding
The stock wraith spire cooler for ryzen is very good and easily copes with 3.7 at low temps. I would not trust it at 3.9.
Intel coolers in comparison are very poor or not even provided.
Waiting now for prices and proper reviews, my guess is the 1600 will be much better value for money unless you want to pay a premium for a relatively small performance increase.
Never seen any charts that showed Ryzen IPC that high before.
I've a feeling if overclocking doesn't get any better on Ryzen, then the actual competitor is going to be the i5-8400 (non-K) at £175, which is full 6 cores, no HT but a boost clock of 3.8GHz on all cores, and with the slight IPC advantage is going to be as fast as an R5 at 4.0GHz+ also it's a nice 65w part so even with the dire thermal toothpaste in the chip hopefully won't run as hot as hell.
If one of the board vendors pulls a miracle of Bclk overclocking on the Z370, like they did with the Z170 (before Intel blocked it) then it's going to be a really hard choice. Dead socket, but could last you 3-5 years if that was the case... it's fun time for the enthusiast.![]()
The choice at all price and performance levels is now very good, before AMD stepped back in Intel was following a similar approach to Apple , premium prices and minor updates for each generation.
It's pretty inane to begin with to rely on 1 workload when testing for IPC, I'm not sure what guru3d is even trying to do there. We need something like these Anandtech articles, various different types of workloads:
We were discussing about single core IPC, which Guru3d is testing PROPERLY. All CPUs at same speed, and see how they scale on single core test.
There bound to be 1-2 points difference between various ram speeds, motherboards, and topologies. But that isn't breaking factor, is as basic as it can be.
You post tests that are relative and depending to multiple parameters. Ram speed, CPU speed, motherboard, core count, potential software optimisations even cooling.
With cherry on top, FOUR (4) architectural different system, where performance matters on multi thread multi core benchmarks.
Infinity Fabric (AMD Ryzen - Ram speed), Mesh (SkylakeX - Ram Speed), Ring with speed running at CPU speed (Kabylake/X, Skylake), Ring with speed running at different speed than core (Broadwel-E, Haswel-E - uncore speed).
