That does Max even less favours, it's hardly aggresive driving from Vettel at all, he eases over to the left and Max panics.
Clear to see why he moves left when he sees Vettel moving over.
Edit: look at the way he works the steering wheel.
Well put simply, not into the side of Kimi. If he kept it straight would Vettel have kept moving over? Probably not I suspect as even Vettel wouldn't deliberately ram someone (other than HamiltonI don't see where he was meant to go? It all happened so quickly. It isn't like he could slam on the brakes.
). It seems Max was fixated with Vettel not realising he had Kimi passing on the left.Well put simply, not into the side of Kimi. If he kept it straight would Vettel have kept moving over? Probably not I suspect as even Vettel wouldn't deliberately ram someone (other than Hamilton). It seems Max was fixated with Vettel not realising he had Kimi passing on the left.
Yes he never stopped moving over because Max didn't stop him, Vettel isn't an unguided missile, all he is looking at is Max moving left as well giving him more space to move into.Vettel never stopped moving over. Max backed off, he had nowhere else to go. The problem was the speed that kimi approached with - neither max nor vettel would expect it. No, vettel would never, or has never rammed into anyone...
He makes two turns to the left, before a panicked right/left "oh ****" moment.Are we watching the same video? His steering is stable and constant until the Ferrari's make contact and sandwich him.
If you watch the gif posted earlier, Max is moving left slowly to make sure Vettel doesn't hit him whilst he tries to lunge across the track,and then Kimi, still with more room to move left starts coming inwards meaning Max gets sandwiched.
Kimi is straight as a die down the inside until Max hits him.
Good point.No he is not, watch the gif the split second before impact. Kimi comes in towards Max.
Also, if Vettel is allowed to come across the track like that and expect the person to the side to move out of the way, why isn't Max allowed to?
Sorry, but where has anyone said anything about Vettel expecting people to get out of his way? Max moved out of the way of his on accord seemingly not checking his left side was actually clear to allow him to do so.No he is not, watch the gif the split second before impact. Kimi comes in towards Max.
Also, if Vettel is allowed to come across the track like that, crowding out the track and expecting the person to the side to move out of the way, why isn't Max allowed to?
Max is in full control of his own car (I think?). If he gets bullied by another driver leaving him feeling that he needs to get out of his way then that's his problem, not Vettels.That doesnt make any sense![]()
Vettel cuts across half the track before Max hits Kimi. Max quite clearly wants to avoid the contact so he goes left.That does Max even less favours, it's hardly aggresive driving from Vettel at all, he eases over to the left and Max panics.
I swear half of this forum have been on class A drugs this weekend. What with the boxing now this, it was Vettel's fault all day long. With the exception of our resident troll, if you can't see that you I'd suggest looking at past races for guidance.
This.
Vettel and kimi tried the pincer attack, and it failed big time.
^^I swear half of this forum have been on class A drugs this weekend. What with the boxing now this, it was Vettel's fault all day long. With the exception of our resident troll, if you can't see that you I'd suggest looking at past races for guidance.
