Unfortunately I was a bit dim when buying it from the *********************. Got it from an Italian seller so has an Italian warranty.
ASUS UK won't touch it and said try ASUS Italy who won't touch it either as need an Italian address to be able to send a RMA and told me to try ASUS UK
You would think ASUS UK would make an exception, but wouldn't budge at all.
Not sure about mentioning other retailers but.....
You should really take a look at the "file an A-to-z Guarantee claim" as the retailer you mentioned has a responsibility, not just the seller.
Point taken tho, always check who the seller is when buying from there.
Tried that, but they rejected it saying it's a RMA issue. Really long back and forth with them where I unsuccessfully argued there should have been a warning on the store page about warranties not being enforceable in the UK if you buy from a non-UK seller and that I had essentially bought a warranty-free monitor. Still wouldn't budge.
My fault for not paying attention to who the seller was I suppose and just clicking buy.
Oh well, won't make that mistake again.
These days I am very careful where I order a monitor from.
It needs to be a retailer with a good return policy.
I purposely bought my Samsung cf791 from a local store with no quibble return policy.
Just in case...
How do you find running Nvidia on the CF791? Do you think you miss the adaptive sync element or not?I haven't found the colour shift bad at all to be honest. No worse than my previous ips monitor really.
Just in case...
Can anyone explain what are the technical reasons behind IPS screen bleeding too much compared to TN or VA?
Isn't it just the lack of Local Dimming which is the monitors' issue regardless of their TFT panel?
