Caporegime
- 9 Nov 2009
- Planet Earth
Comes with free flickering, too.
Really?? Mate has a RX570 and a £100 FreeSync monitor and it has no flickering at all??
To be honest the cash you would save buying a Ryzen CPU and god forbid a Vega 56 instead of an 8700K + 1080, you could pretty much buy a Freesync screen with the cash you saved, lower fps? who cares your getting adaptive sync gaming baby![]()
Only the samsung models iirc. More of a joke than a statement
*Turns out its quite a few models*
https://www.reddit.com/r/Amd/comments/5721lj/has_the_freesync_flicker_ever_gone_away_100/
Not heard anything back from him about flickering - he is not an enthusiast so I am sure he would have harranged me for tech support otherwise!!
Edit!!
If you want to cherry pick things you can look for GSync flickering too:
https://www.reddit.com/r/nvidia/comments/632e3x/gsync_flicker/
The 8700k makes sense to me.
I'm not cherry picking it was the first hit on Google lol. It does seem to be Samsung affected the most, given as they supply a lot of panels to other manufacturers that would explain why it's not just one brand.
It doesn't to me - looking at the pricing,meh. I still remember when a top end consumer Core i7 was between £200 to £250. I could get a 4C/8T Xeon E3 for around £170 to £180. In todays lineup that would be like a locked 6C/12T Core i7 with no IGP for under
Its why I am likely to avoid Coffee Lake and Ryzen MK1 if I can - I expect with Zen 2 and Cannonlake/Icelake core counts might go up further,so it will mean 6C/12T will be pushed down the stack a bit more.
Its is TBH - that page was also on the first lot of search results too. You do realise that the panels are shared between FreeSync and GSync monitors - it will be the scaler which is different.
How does a high binned 7820x with 4ghz+ memory compare in single threaded applications like games out of interest? Can't really see anything on the web with high speed ram which has been mentioned helps performance.
Josh.
Ram is also more expensive now, as are a lot of things. A different way to look at it is last years i7 costs the same as this years with 2 extra cores and 4 extra threads. Yeah, intel have killed off the xeon in mainstream boards and that seems to only be about cost.
Zen 2 isn't out till 2019 according to that slide, and thats not even the 7nm 5ghz one that people actually want.
It seems the GPU is at fault in regards to samsung being the issue, vega doesn't have the issue I mentioned : https://www.gamersnexus.net/guides/3028-samsung-cf791-freesync-flicker-criticism-tested-on-vega
Except that it does't fit the purpose for streamers...
Do we think 3200mhz CL14 RAM is going to cut the mustard with 8700K?
Intel uses chipset PCI-E lanes for the M.2 slots, so unless you use one of those PCI-E to M.2 add-in cards, you shouldn't eat into the 16 PCI-E dGPU lanes.
The Z370 chipset has 24 PCI-E lanes that are used for various I/O, the only downside is that if you try to RAID multiple NVMe SSDs, you might encounter the DMI 3.0 chipset to CPU link bottleneck (but NVMe RAID is pretty serious overkill to begin with).
Not In heavy memory work loads assuming Coffee Lake is Skylake +2
Could you explain this a little more please? I wasn't aware of the 7700K favoring high speed RAM really?
