Caporegime
- 18 Oct 2002
Yeah the 49" tempted me, but then I just pulled my PG348Q closer to me for the same effect
Yeah the 49" tempted me, but then I just pulled my PG348Q closer to me for the same effect![]()
Do you get the image stretching at the sides on your 34" screen?
Well I caved and got one of the 49" CHG90s.
Cheers.
It's a kitchen worktop I got from a local joinery place, I'd measured up the width of the room and had it cut to roughly that size, built some supports against the wall for it, then when I got it into the room cut it to size fitted it and put the legs on for aesthetics and support at the front.Is the desk top an ikea job with added legs?
I ended up returning the 32" model, The HDR feature was just not good enough with it's measly 8 zones, Brightness was not up to HDR10 standards, And the minimum Freesync range was too high for my liking, Maybe in another year or so when they have a much lower minimum Freesync range and at least a few hundred dimming zones like other HDR monitors akin to Dells which has 384 local dimming zones.
Damn shame that, looks so good on paper![]()
Indeed, It's nearly there though, If they have the same Quantum Dot 144Hz panel BUT with a lot more local dimming zones and a much lower Freesync minimum then it will be an instant buy for me.
How much will that cost?
Why would you want to update the firmware on it?
Cool, just hadn't seen the info. Is it documented anywhere you've seen?Because one of the fixes in latest Firmware was to increase Free sync range.
IF only they had 4k 144hz HDR GSync 1ms, my dream monitor
