- 30 Nov 2011
I'm remaining positive about this. I'm not sure there's much point comparing VR tech with the visual experience of a single 1440p monitor though. In my Rift I lock my FPS to 45 and still only manage low/med settings in Project Cars with a 980Ti. If the 8k (which isn't 8k) achieves respectable (or close to) HD visuals with a single 1080Ti at a stable FPS, and I can see further into the distance with reduced blur, then I will be one happy bunny...my pledge is the same as I paid for my Rift and I'm fairly happy with that purchase. The fact I need to build a new PC to get close to the performance requirements is just icing on the cake like I needed an excuse.
I'm not comparing them visually, just in terms of how much horsepower you need to drive how many pixels and framerates - I know what it takes with a 1080ti to go from 90-120hz varying frame rates to 144 locked steady and have played with 4k and frame rates too, when you say something like 5k or 8k it sounds really daunting, but it doesn't have to be as cranking up every last setting in VR doesn't gain you much and you can gain back critical frame rates by dropping most settings without massively affecting visuals
Cope with what though? Watching a movie? Playing Crysis? 90Hz or 45Hz, this is a huge difference which I realised using a 1080Ti and both super samping at 2 and turning up the pixel density within Dead Effect 2 VR (2160 x 1200 x 2 super sampling x 2 pixel density = 8640 x 4800).
I really like how the Pimax HMDs are looking so far but some claims are just silly.
you're only having to do that now though because the headsets are so low res so you have to massively oversample everything to get some semblance of visibility... with a much higher res headset you only have to match the pixels available and it will still be clearer than what we have now
the 5k and 8k will only accept 5120 x 1440 which is 7mp compare with the 41mp you are talking about, even at 1.5 super sampling its still only 14mp and it will still look far better than trying to cram 41mp in to a 2.6mp area on the rift/vive.
