OcUK Cinebench R15 benchmark thread
Thought I give OCing my 4770k another go. Always had issues getting above 4,3 and blamed it on the lottery. Well jokes on me cause 15 minutes with the haswell OC guide over on overclockers.net and behold 4,5ghz.
Ryzen multi scores, various speeds and ram timings/speeds. Top one wasn't stable but did actually run.
Second from top 1700X @ 3.925 with fairly tight 3333 ram timings(14-13-13-13-28-42)
Not many 8350K users here, my first build for my Dads new ITX PC, memory at 3000Mhz. Strong single core, which was the aim of the build, multicore is fairly poor, but playing flight sims and watching steam trains on youtube, he has the right CPU for his budget!
That's higher than my i7 3770k at 4.3 :D
you probably could get 4.6ghz too with just over 1.3v :D
I think i'll have to delid before i will attempt anything over 1.28 cause the temp spike is huuge. 1,3v will put me near 88 degrees on my AIO with noctua SP fans at max RPM.. Have a feeling the thermal paste job by intel is shoddy.. what a shock haha.
Still stock Haswell i7 level's of performance for the multithreading.. which is good imho and yeah singlethread is a good bit ahead. Wonder how it holds up in games .. poke poke..
Yeah get some liquid metal on it but make sure you paint the VRM bits before you do that.
Good evening all.
First off, thanks to @CAT-THE-FIFTH for posting a video about MCE (Multi-Core Enhancement) being on by default on an Asus board in the Coffee Lake thread. I had never heard of it until yesterday but prompted me to have another play around in the bios and I have managed to gain an extra 200mhz on my i5 6600K.
@4.7Ghz the score was around 787/ 190ish, now at 4.9Ghz it's 812/213 which is not far shy of the i3 8350K above but I'm not sure about the temps for a 24/7 usage.
How much of an impact does having higher speed memory affect this benchmark?
But but but Jumper, Linus from LTT says that delidding isnt worth it and will only yield a few lower degrees /j. Sorry i couldn't help myself.
lol
i apologise for the appalling ram timing and speed. the z270 gaming 9 really isnt upto the task of decent ram oc.
My own experience yesterday with my 8700k at 5ghz dropped by a massive amount after a delid. Gone from 95c into thermal throttling down to 65-70c. Still using toothpaste.
