Do all the boards have MCE so I can run at 4/3.8?
Ibdeed i speced my mate 1600 build. He can but it together but bios is wizardry for him. Long story short he assembled it selected 3200cl16 xmp that hes ddrs are rated at and ... Not had a single bsod or problems. Thing is stock 1600 boosts ONE CORE to 3700 and rest is like 3400. And stick volts are well You know how those are haha.Like getting ram to run at rate for example?
I don't think there is a list available, nor have I seen that advertised on the specs for the boards.
However, the Z boards atm all seem to have the same features. The people kicking off is just because asus has it enabled by default.
Do all the chips have the ability to run at 3.8Ghz?
Where did you read that only 1 core gets to 3.8? As every person I've seen report their 8400 speeds get 3.8ghz on all 6 cores, some even with MCE disabled.Nope. 3.8Ghz is 1 core speed. The rest are as good as 2.8 only. The great unknown lottery.
Get a 1600 and OC. Is 6/12 not 6/6 with dice rolling speeds.
I'm sure it's all from that AdoredTV video where he speculates without any actual evidence, only hearsay. No examples from buyers.4.0GHz on one core, 3.9GHz with 2-4 cores loaded, and 3.8GHz with all six cores loaded
You well wrong
You well wrong
Intel doesn't guarantee those speed, but you do?4.0GHz on one core, 3.9GHz with 2-4 cores loaded, and 3.8GHz with all six cores loaded
You well wrong
I think i will block the trollIntel doesn't guarantee those speed, but you do?
But when have locked CPUs ever been a lottery?Lottery just like any CPU.
Ah more bs being spread by people that don't own the product.
I need a new home where the members are not using some YouTube shills words as gospel.
There is zero evidence that shows the 8400 only running at 2.8ghz.
Not really. I don't need to own a Ryzen to know what it is capable of, it's been out for 7 months now, so much is known about it's strengths and weaknesses. On the contrary I don't need to own a 8700k to know that it clocks higher, has better single core performance and in general is a faster gaming cpu.It's bizarre to learn that some die-hard defenders of a CPU or manufacturer currently don't actually own them and have no experience of using them. Just, weird. Essentially their points are all based on someone else's numbers that they want to agree with.
I'm not quite sure I understand where you are coming from. Are all those that don't own a certain piece of technology therefore forbidden to talk about it? That's weird and this forum would be quite strange and empty place if that were to happen.
Regardless we have two manufactures of cpu's and depending on your particular needs will determine what is more suitable. Not everyone needs to chase numbers.
