That's what I've used, mixed with some IBT and Realbench as the latter helped weed out that a touch more voltage was needed.Prime95 small FFT still the go to test for stability?
There are plenty of options, the fan can go on the back or can be raised above the memory as @Ste suggests. Apparently the cooler is still very efficient even if run with only a single fan.I worry RAM clearance is going to be an issue since I'm using 45mm tall kits, but I reckon I could just mount the front fan at the back.
a lot quieter with stock cooler than my main rig with a Corsair GT 110i.
. The Surface 4 is a massive step down compared to it in terms of encoding times...
. A quick CPU stress test, then turn off the PC and twist the cooler while you take it off.
