?????Looks like I'll be sending mine back to Nintendo due to the creaky loose joycons.
That's 30+ hours of Zelda I'll have to replay.![]()
Well from chatting to them online they will probably just replace the whole system as I'm still within 30 days of purchase and they are unsure if it's an issue with the Switch or the Joycons.
hypetrain.gifMario odyssey reviews supposedly leaked. 10/10 in Edge and 39/40 from kotaku.
Can't wait![]()
How is your Wifi strength (2.4GHz not 5GHz)? Both models that had the problem also had poor WiFi signal compared to the third one.
Mine sucks it has 2 meter range, my first two switch could at least get 4-5 meters, I sent it to nintendo they said no fault found.... so i sent back again
I actually prefer playing Zelda with the detached joycons than using pro controller.
