Is that a stock seat or comfort?
Comfort. I bought it after sitting for 10 hours on the stock seat. Never again! Plus it looks better too.
Sounds good!
Got it tuned. Base run was 161hp and 73lb/ft at the wheel. He managed to get it to 167hp 75lb/ft. I expected a little higher but it is the S model so doesn't rev as high. Gained 10hp between 5k and 7k though which is nice!
Didn't even know there was an S model... what's the difference? Is it US only?
If the fuel line is in good shape it doesn't need replacing just give it a good check make sure it's not splitting or cracking. Everything else you've listed is as easy as an oil change and can be done on the side of the road if you really need to.
Brakes, oil change and air filter are easily done at home.
Brakes really aren't difficult if you get yourself a bleed kit, I did it myself for the first time on the dirt bike, R6 and my dad's R1, easy.
Oil and filter is simple.
Air filter I'd just buy a new one, not entirely sure you can clean them.
Hoses are easy too
Oil + filter £16
Air filter £15
Brake fluid £3
Coolant £15
Plugs £10
Total £60
About an hour and a half work.
Most garages around here want at least £200 for that level of service. I'll happily pay myself £86 an hour rather than them.
