I'm not showing all my cams but this is from the side of our house. No lights at all apart from the Cam IR this is a 2342
Yes its messy. We're mid refurb.
Thanks for the pic. That's why I'm keen to see something from a 2335 as I also, like you, thought the 2342 was very impressive when I had one temporarily (as a test) before returning it.I'm not showing all my cams but this is from the side of our house. No lights at all apart from the Cam IR this is a 2342
Hopefully @Scream will come and enlighten us (excuse the pun hahaha)If the 2335's a better than those then I'll move my 2342's into the garden and driveway. As they are lit and buy some 2335's for the darker areas.
In layman's terms what's the difference between the 2335 and 2342 that you said you didn't like?
Thanks for those! That is a fair difference but is it enough when considering the drop in daytime performance? To help decide is there any chance you could please post a daytime comparison from the same positions? Or do you not have one?The 2342's are rubbish in darkness as they are not meant for low level light.
The 2335's are low level light and are classed in a similar group as the dark fighters.
The 2342 are slightly better and sharper than the 2335 during daylight but at night the 2335 is superior.
Example from another site. Every location is different so you have to make changes to image settings to get the best.
2342
2335
Its not all about IR though.The IR of that cam doesnt seem that good to me. My old DS-2CD2235-I5 lights up nearly all of my garden in the pitch black and has a reasonable picture quality and thats on a 4 year old camera.
