ordered the 5ghz chip + taichi board + 240mm cooler,do your best mate ,cheers!Depends on voltage. Early 70s to mid 70s stress testing none avx....
Gaming 60s.
To nutkins make sure nothings running that doesn't need to be or updating in background as you'll lose a few points . what speed in memory at ?
3600, as per the profile.
Ran AIDA64 for a little. Clock sits at 4.8-4.9. Will never touch the 5.2GHz it should reach (as far as I'm aware, AIDA doesn't run AVX instructions).
In testing totally fine ofcourse. Check Realbench, heaven etc.. Disable avx offset if necessary just don't rum avx stress tests.
Check power plan in Windows, check igpu isn't installed by some windows update.
Yes it does, there's AVX instructions in the conventional CPU test routines as well as FPU, now. Which is slightly frustrating in my opinion as the CPU routines were a good starting point for non AVX clocks.
