*Rumour* 1070 Ti (Videocardz.com)
I have roughly £450 at a push to buy a new card. Do I go with 1070 or the 1070 ti? A 1070 would save me cash for other things like a new case that I want also.
Or would it better to wait for the reviews first?
Yes but you do the same with TV discussions amongst other things. Overkill this and overkill that.
I don't think I have ever said any tv is overkill unless it was someone buying an LCD when OLED is available or when plasma was around.
again that is correct so that is why i said it.
You just linked me to a site that says very high settings minimum of 47???????
NOT ULTRA
I think that's with no msaa as well so no where near what people would consider max. Guru used 2 x msaa and the average was 90. 4 x msaa would probably drop that to 70 and who knows where the minimums would be. Here is gtx1060 running the game with plenty of settings turned off. He said max in his description but then said this.
alright, let me clear this up a little bit. The title is slightly misleading, yes I have a lot of settings maxed out, but I also turned some off because they took away a lot of performance and I don't think those settings are worth it.
With Maxed out settings this game might be playable but most likely around 40's.
He has basically done what i would do and keep the important settings at Max and drop others that i wouldn't need for a good gaming experience.
Maxed settings in GTA V is silly.
Who the hell needs MSAA in reflections from puddles and mirrors?
I never max settings in any game even if i can as some settings make things look worse and some are pretty pointless. the main points were about some cards being overkill. Lots of people will just want to know they are pushing out good fps with Max settings regardless.
yeah I haven't played gta5 yet been waiting until I had something fast enough. I should be good for 4xmsaa with my 1080 when it gets here and my 8400 when they come back in stock.
Looking forward to seeing how good games can look this 280x is bit dated now.
Was over at my mates the other night playing it at 4k on his 1080ti. We were playing it in first person mode and the game looked absolutely stunning and playing it in first person was like playing another game. Already completed it on ps3 and ps4 in third so needed to add in another element.
Yea you should be good to go with that setup.
