What have you done to your car today?
Good sign, means you did it in good time ;)
Yup. I'm also fairly light on the brakes so it doesn't get a huge amount of punishment. Noticed a massive change to the brake feel since I got new pads and discs last week though. Worrying considering the car was telling me the others had 80k left on them...Also seems to have solved the mysterious squeaking noise that BMW couldn't fix but could hear.
So, I went on eBay...
... and ended up with this slightly tatty, but seemingly very solid, '96 XJR. Always admired the AJ16 straight-six engine and, after a great experience with my 4.0-litre Sport, had always hankered after an R. This one was local and inexpensive so I couldn't really turn it down. Launch colour, too!
As it sat in the morning.
I then spent most of the day cleaning the engine bay, as it was a bit filthy. Not a pro job, by any stretch, but at least I can see what I'm working with.
I did get around to going over the rest of it, too.
So, now it looks like this:
The front wings have had it, and it's got a little rust to the underside, but it's all there and works - including the air-con and rear heated seats. I'm not entirely sure the little M90 is putting out as much boost as it should be (feels like the bypass valve might be jammed), but it does drive very sweetly otherwise.
All I have to do is work out what I want to do with it! :D
Been working on the Subaru, too. Fitted an "Ultra Racing" front strut brace from eBay. Wasn't expensive and turned out to be pretty decent - fitted correctly, feels solid and did make a difference.
Fitted a Whiteline quick-release rear tower brace as well. Yet to test this out to any extent but it went in quickly and easily. A little trimming lets you retain the OEM sound deadening pads and trim panels, too, which is neat.
Also got the transmission fluid changed; at RCM it had some general Castrol fluid slung in and the gearbox was quite balky and sluggish, particularly at lower speeds when cold. I got the fluid replaced with a 50/50 mix of Red Line Lightweight Shockproof and Motul Gear 300.
Much to my surprise - I wasn't expecting much - it's made a substantial difference to the transmission. It's now much slicker, quicker and less reluctant to engage when rolling slowly along. The snick has basically gone, too. Consider me blown away. The blue colour of the Shockproof took a bit of getting used to, though.
Lastly, the factory-fitted (and seemingly original) self-levelling rear dampers finally gave out - leading to it squatting at the rear all the time. I ditched the whole lot and fitted a Pedders drop-in replacement kit, which does away with the SLS and includes new top mounts. The Forester's now returned to the right ride height.
Rear arch gap before:
After:
Sits a lot better now and certainly rides and drives better, too - particularly when loaded.
Extremely happy, for once. Pleasing for everything to have a positive effect and actually improve things. Even managed to fix the rear wiper by fiddling with a scrapyard motor.
Now, perhaps for a little more power and noise...
Having ignored goodwood and their multiple offers of 'fellowship' membership they have finally offered me full membership. Shame I have moved further away since being on the waiting list, if I was closer I would join.
Add turning in to orange crust to that list too
Imported in 2007, undersealed and cavity waxed in 2013. Hasn't done many miles since import really. 8k in the last 4 years. Arches, sills etc look solid and underside looks fresh too so hoping that it'll be fine without any nasty surprises. It's a MK1 too, bit more solid than MK2 NB.
Looking and being solid unfortunately are two different things with MX5 unfortunately.
Not all of them. My MK2 is now more solid than most mk2s and mk1s on the road now
Oh I know, it's only so much I can do before buying, I checked the main areas and all looked and felt solid so hoping it has no hidden surprises
I had a good feel and a good poke when I bought mine. It was only a few months later when I removed all of the plastic undertrays and liners etc that I found that the inside of the chassis legs where I couldn't see them had gone rotten.
Fortunately you won't have that particular worry with a MK1. :)
Been waiting ages for this but just got a dyno developments chassis dyno delivered to the workshop in the last few days. It's sick, so much better than trying to tune on the road.
Did a quick power run of my road tune that I've been running on for the last few months. Baseline pull of 300 flywheel horsepower @ 10 psi with 8 degrees of ignition timing.
Been doing some last minute wiring of sensors/servicing on the Supra tonight and tomorrow morning I will be starting with a fresh map using a different fueling strategy and see what power I'm given once the fueling system is safely maxed out at around 16-18 psi of boost. Can't wait to dial in some proper ignition timing, tired of the car feeling so flat!
Uber jealous, shame Canterbury is so far away.
If you don't mind me asking how much did it set you back?
For some reason I thought your car had about double that. :p
The internet Supras have skewed my expectations!
With the 4WD Dyno system, Ventilation System & Dyno Cell it's close to the 100k mark and building of the room/sound deadening hasn't been finished off yet either!
Nah mine is still a baby in comparison. I will need a bigger turbo and uprated injectors/fuel pump to push to the 600hp territory. So maybe sometime next year :P
Yeah the internet makes it seem like building a 1500hp supra is the norm.
Nah mine is still a baby in comparison. I will need a bigger turbo and uprated injectors/fuel pump to push to the 600hp territory. So maybe sometime next year :p
Fairly typical costs from what I've heard from others then. Anything in particular that drew you to Dyno Developments over the typical Dyno Dynamics/Maha/Dynapack?
I could write a lot about this topic but I'll try to keep it short.
The main issue we experienced on a few dyno's previously was wheel slip on some of high horsepower builds. Obviously there will always be an element of this with big horsepower RWD cars, but having a 400hp low boost pull slip on an inertia dyno got old really quick when trying to get accurate graphs to analyse afterwards.
Dynapack would have been a top pick for this but frankly it was out of budget. We have a few Maha's in Kent, and for the money asked it just wasn't convincing enough. Super loud on wind down, traction issues on single roller etc.
That left us with Dyno Dynamics, but to make a long story short, they are no longer the company they used to be after going bust and re-forming. Dyno Developments was created by one of the Dyno Dynamics engineers/geniuses and he has continued the original DD system but giving his own twist on things and implementing his own technologies that help with load control, traction etc etc. So in a nutshell, DD but UK based, super knowledable small focused team and better systems.
