Thanks.New build posted yesterday evening.
@TonyTurbo78 @AMDMatt
If I record a video tomorrow showing me trying to overclock VEGA 64 can you guys give me some input what am doing wrong?
Tony remember couple weeks ago I had my Memory clock speed jumping all over the place well I think I have found out the issue.
if I set Wattman to Balanced mode my core speed with be 1400+ until target temp is reached then it remains around 1300+ memory speed remains 945mhz with odd drop every often. But if I set Wattman to custom and leave voltage on Auto I get same clock speeds etc All seems well But here what I dont understand if I change the Memory voltage to anything below 1000 my Memory will jump all over the place 500/800/945mhz
I noticed you guys run 1100 @950 I cant even run 950 at stock 945mhz if I try and change core voltage down I get lower core speeds down to 1100/1200 vs leaving everything on Auto voltage lol
A video will explain it better am sure
So all this time I had my VEGA and messed with Wattman I have actually been making my performance worst!
Sure dude no probs. I'll do my best to help, completely mashed from last night, only got in a 8am this morning![]()
Do we still get a couple of free games included ?
As per the bottom vid, its a 56.
Going back to Green ?
Me? No. I just can't live with such a noisy card sat up besides me on my desk.
I bought an RX470 off the MM a few weeks back so if the V64 sells I'll use that until the non reference Vega's land or if it doesn't sell I'm going to stick an AIO on it.
I find noise no issue for me sitting next to PC 40% fan speed with headphones on I cant hear it.
40% isn't enough to keep it from throttling though is it? Maybe it's due to my small case but here 40%'s nowhere near enough, In order to get a pass in the Firestrike stress test I had to use a 70% speed to avoid throttling under the 97% failure point.
I ordered a pair of cheap headphone from OCUK yesterday so I'll hopefully get them Monday. I'll still be getting the AIO when it's available though
My target temp is 75c and using Balanced mode until I figure out my Voltage issues. My core remains at 1400+
Fair enough. Voltage issues?
