The game is all about the traffic! If you got rid of it you'd have nothing to do!is there a DLC to remove the traffic
Will be formatting my C: drive soon does anyone know how I can be sure I wont lose my save/mods? Pretty sure I save the maps but not sure if steam will remember what mods I used.
Yes mate. Everything is in appdata tho! managed to find it all.Do you have another HDD or partition? just copy the Steam apps folder to a different drive then put it back after you formatted and installed Windows/Steam.
Is that Arrow head Valley/junction map? Are you wanting to work with others like a collaboration?
Thanks, grabbed the base game for €4.17, well, was actually the Deluxe one, but since it was cheaper then the base thought I could as well. Will have a ponder around and see how it is. Loved the Sim City games until that disaster that EA made after SC4. Heard good things about this one though so hopefully it be some fun.The base game should be enough to see if this game is for you.
As for mods. Without the traffic president or whatever it calls itself now I dont think I could play it. And the road anarchy mods.
Its good fun. Much better than SC2013Thanks, grabbed the base game for €4.17, well, was actually the Deluxe one, but since it was cheaper then the base thought I could as well. Will have a ponder around and see how it is. Loved the Sim City games until that disaster that EA made after SC4. Heard good things about this one though so hopefully it be some fun.![]()
