Interesting, thanks for the share.Looks like you have a touch more bandwidth than mine @ 3333 so you're not loosing out at all.
This is what mine was at about a month back.
NUMA 3200 C14-13-13-28-42-256-1T tFAW 18 tRDRD & tRWRW SCL 2
Remembered to do this. 1950X stock scored 166 cb single core in Cinebench if that's still of any help. That's using the Asus X399-A and 3200 mems and SVM disabled (virtualisation).Yes definitely not enabled that. I am using a more recent bios version i think, but as i have Raid Nvme now i can only roll back so far and no earlier bios that supports Raid has helped so far.
It's not a huge issue, but now i know performance has dropped it is annoying me.![]()
Yeah i did get a score or two near that, and i think one even beat that but now it has dropped a bit. Ah, think i will just give up worrying about it for now.Remembered to do this. 1950X stock scored 166 cb single core in Cinebench if that's still of any help. That's using the Asus X399-A and 3200 mems and SVM disabled (virtualisation).
I actually cant remember what they do now. IIRC, TRDRD & TRWRW affect read and write latencies. I've never been able to figure out why my cache data rates are slower than the 1950x but looking at @sandys result, they are lower than mine so maybe it's related to the number of cores.Thanks for the share.
Interesting results. You have higher mem bandwidth all round, but lower CPU cache scores.
What difference does 18 TFAW make? I think i am using 24. What about TRDRD too? I am already on SL 2 & 2.
Don't think so, but combined scores seems to be all about low driver overheard and CPU IPC so not that favourable for Ryzen/AMD when running standard firestrike. Less of an issue at Firestrike Extreme and 4K as the bottleneck is the GPU. Firestrike standard is more a CPU test these days.I actually cant remember what they do now. IIRC, TRDRD & TRWRW affect read and write latencies. I've never been able to figure out why my cache data rates are slower than the 1950x but looking at @sandys result, they are lower than mine so maybe it's related to the number of cores.
Out of interest do you see comparatively low firestrike combined scores compared with the 1800x?
I actually cant remember what they do now. IIRC, TRDRD & TRWRW affect read and write latencies. I've never been able to figure out why my cache data rates are slower than the 1950x but looking at @sandys result, they are lower than mine so maybe it's related to the number of core.
You have to assign the NVMe Boot disk as a Volume on the array and then load the raid drivers when doing the install, or at least that is what worked for me.
On that note, I am seeing poor performance when trying to use my new raid array and transferring between two disks on the controller.
Independently the disks are great but transferring between them which is surely why you want nice fast discs it can be slower than a normal SSD/HDD, any tips.
Top two tests are independently run, bottom two tests two disks, (1 drive, 1 Raid0)thrashed at the same time, spu is not being hammered so am unsure why I have this bottleneck, should be no bottle neck with all the lanes?
Despite much testing, tuning and trying other peoples exact settings, i cannot get my TR and Ryzen samples any higher on the memory than 3200Mhz. However i did manage to get CL12 3200Mhz @1.45v on TR.
I've got no idea, but it seems a lot of people can get 3333-3466Mhz stable. Guess we're just unlucky.Seeing the same behaviour.
Have CMR32GX4M4C3466C16 (B-die) in the Aorus 7, where that RAM was well cheap on amazon compared to anything GSkill.
Using XMP, giving 3466 w/ VDDR @ 1.35 and VSoC @ 1.1 the PC is not stable under prime/memtest, but runs surprisingly well.
Dropped the frequency to 3200 w/ the same voltages and it's smooth sailing.
Wonder what the major factors are in that 3200MHz being a common achievable frequency, if its the signalling, IMC or something to do with the die-die interconnects?
