I think I have sorted the above issue regarding the dullness. Tweaked a couple of colour options in Nvidea control panel. Sorted
mind sharing new photos as a comparison? thanks
One on the right looks far too high in contrast, it's all washed out.
Ordered a replacement, should arrive Wednesday.
Well it has arrived, but can I get the base fitted, can I heck! Either I am being a moron or it is the worst designed thing ever!
Ended up just buying one as a Christmas treat to myselfNo problem at all. I have trust enabled so you should be able to PM me. More is always better though: I have colleagues who use 3 monitors when in the office !
. Thanks very much though.Glad I'm not the only one! Mine arrived today and I tried doing it with a knife to no avail! Can't get the screw in flush (I assume it needs to be completely flush so the base can't wiggle?), so having to pop out tonight to get a proper screwdriver to try.Well it has arrived, but can I get the base fitted, can I heck! Either I am being a moron or it is the worst designed thing ever!
Ended up just buying one as a Christmas treat to myself. Thanks very much though.
Glad I'm not the only one! Mine arrived today and I tried doing it with a knife to no avail! Can't get the screw in flush (I assume it needs to be completely flush?), so having to pop out tonight to get a proper screwdriver to try.
Yea i was playing around with it. I went into the nvidea control panel display setting and changed the colour settings. Everything looks a lot more vibrant now.
Really happy with the AOC. just needs tweaking once out the box
Make sure the base is fully slotted into position. It took me two goes, I was just about to get my screwdriver when I tried pushing the base into position a bit harder. I didn't feel it shift but suddenly I was able to screw it in by hand.
