Titan V announced £2700 15TF 12nm Volta
Man of Honour
21 May 2012
Dalek flagship
Keep the pics and benchmarks coming :)
First run on Firestrike Ultra.:)
https://www.3dmark.com/fs/14422747
These cards are a bit special.
I got the impression from early benches that they were not good on Firestrike Ultra but it seems this is not true.
I am going to try running a card in my 6950X system as it seems to be better at getting the best GPU performance.
12 Dec 2010
Washington D.C.
Kaap what does your GPU core start off at and end up at once the temps have stabilized?
Mine - 1945 MHz and then high 1800's depending on the benchmark/game. The higher the resolution, the lower the clock seems to get with the increase demand.
Man of Honour
21 May 2012
Dalek flagship
It depends on the benchmark but I am getting much the same as you describe above. With Firestrike standard it is easy to get above 2000mhz but with Unigine Superposition maxed @4k it runs just above 1800mhz. Running Superposition at that resolution is quite impressive though as it is faster than 1080 Ti 2 way SLI !!!
Man of Honour
21 May 2012
Dalek flagship
Lol, the poor pleb can't even afford high spec ram, using budget stuff with no heatspreaders :p
I am glad you said it first !!!
Nice waterblocks for the CPUs too would look and work better.
From experience 4 way Titans on air are quite noisy if you ramp up the fan speeds, it is ok for benching but not much use for 24/7.
5 Sep 2011
Surrey
Why would he need heat spreaders? You're not going to be doing a lot of memory overclocking (none to be exact) on that board. This might surprise you but some users do have a use for these cards and it's not just throwing money away lol.
